just wondering if a 6pot rad fitted on a 4pot would affect the mpg? recently remembered we ordered one when the gasket went and just chucked it in as i had no time,
been going through loads of threads about poor mpg for a long time, sensors were changed, plugs and ht leads, new gaskets, all about 2 years ago,
i recently found the petrol leak tightened it and thought this was ittt !!!!
however i put in £30 about 22litres - 4.83gallons, drove like a complete and utter b*tch keeping it under 2k and feathering the throttle, i calculated it and im getting around 20mpg still!
the car doesnt heat up immediately as it should, after a 30-40 minute drive its still just around the 1/4 mark, however the heat comes out as it should a few minutes after setting off,
engine otherwise seems good, its very smooth, very tappety though.
can a 6pot radiator on 4pot cause poor mpg?
Type of rad. isn't going to affect MPG. It's only jobs are to supply the engine thermostat with a supply of water cool enough for the stat. to control the temp., and to lock up the viscous fan coupling when required.
If it's taking a long time to warm up (which will ruin your MPG, and rapidly destroy your engine, unless you run it on LPG), then replace the thermostat.
Andyboy
- Alpina Colada
It's possible that the rad is too big, and that there is just too much coolant and cooling area. The cooling capacity is meant for a six cylinder engine which holds (and needs) more coolant. It should eventually get up to temp but out on the road at speed, it may well run too cool.
If it's running cold, then the ECU will still be telling the injectors to fire too much fuel in - the coolant temp sensor will tell it to.
As a stop gap, blank off about 30/40% of the rad with cardboard and see what happens. If it starts to run at about half, you'll know whqat the problem is. Fords used to be buggers for this and tyhe cardboard trick made them warm up faster, stay hotter and the fuel consumption reduced dramatically. In the depths of winter it's not a bad idea to fit a hotter thermostat anyway. A couple of degrees hotter than normall is far less harmful that too cool.
