My 320i auto, battery wont hold its charge and wont turn the engine over. The solenoid just clicks. I am guessing it has died.
I have checked all the earth terminals and cleaned them. It will start with a booster battery. What is the best repalcement for it? I dont use it every day. what's the best buy?
What battery?
lammy
jimbob29
new battery or a good secondhand one?if its not used for long periods a trickle charger connected to battery mabie??
Fit a 096 battery, and if you don't intend to use the car for, say, a month, disconnect the earth clamp on the battery when you leave it. This will result in two potential problems:
1/ The engine ECU can loose its idle settings, but in practice I find this doesn't happen when you disconnect a good battery.
2/ If your instrument cluster has NiCd batteries that are in any way past their best, they will probably fail completely, or, if it has lithium batteries, they will eventually discharge, but this should take many years, assuming they haven't been disconnected for long periods already, in the past.
Don't, under any circumstances, allow a discharged battery to be exposed to temperatures below freezing.
Topblag
Brianmoooore wrote:Don't, under any circumstances, allow a discharged battery to be exposed to temperatures below freezing.
Please tell me more about your last point above.
Is this a risk to human life or will the battery never come back to life ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Battery will die. Could also be a risk to human life as well, I suppose, if the case cracked and leaked acid everywhere.
lammy
thanks for the pointers. I'll do that with my new one. can you give me some more detail on "096" battery? is that ah rating? any particular make?
i have a Cetek trickle charger, is this good or bad for the battery?
096 is a particular size and configuration of battery. Comes in many makes.
I believe your charger is a fully automatic one, so should be fine to leave permanently connected, with the battery connected to the car as well.
Andyboy
- Alpina Colada
I would leave it connected up - providing it doesn't have a car alarm or a battery drain. A good battery will be okay after 2-3 weeks. As for which make, I've found Halfords batteries to be good as well as Bosch. BMW ones are no better than any other budget battery despite a steep price, and have a useless warranty.
