Fitting Polybushes
randomspeedfreak
Alright lads, just about to take on fitting my polish polybushes.
any advice i havent done it before?
got the eccentric ones, and removed the old out of the front lollypops, now these new ones come in two parts and appear to need some trimming?!
anyone shed some light?
cheers,
Matt
cheers,
Matt
- E30 Zone Meets/Events Team
Poly bushes should not need trimming, they should fit without too much hassle.
Remember to line up the marks on the eccentrics.
The 2 part lollipop ones, will need the smaller of the 2 pushing in front the front to the back of the car.
- **BANNED**
Check to make sure you fit the lollypop bracket bits the correct way round
they are a propper bugger to get out when you get it wrong!
No trimming should be required,the pin bit should just slide into the bracket part after coating with the (supplied)copper grease.
Youth is wasted on the young.
randomspeedfreak
Thanks for the help lads. Ill post a picture of these I'm pretty sure they need a big mould taken off them!
I wasn't supplied any grease should I use copper slip or find some moly?
How does the bush not rotate the inner under load? How does the second (smaller) part not rotate inside the larger outside bit? Does it need sticking in?!
Thanks, matt
Thanks, matt
Barx325i
coppergrease yep.
Do not use any lub on the poly's, if you do, all it will do it spin the eccentric.
- **BANNED**
Grease the part that fits on the wishbone pin with copper slip,press the other bit into the lollypop,do not lubricate the outer edge.Rav335uk wrote:Do not use any lub on the poly's, if you do, all it will do it spin the eccentric.
The aim is to reduce the friction between the two poly components.
Ianb
You say it looks like the Poly's need trimming - did you just remove the rubber out of the Lolipops ? It sounds like you may have left the metal outer bush sleve in ? If so cut it with a hacksaw (threaded through the lolipop then reattach the blade - once cut the outer metal will spring allowing removal ) but be careful not to damage the lolipop itself.
randomspeedfreak
ill just go get my camera and upload a photo so you guys know what im on about, that will explain it much better
randomspeedfreak
ok ive taken my dunce hat off and figured it out i think.
ill upload a picture anyway
randomspeedfreak
okay the definatley dont need cutting, that was me being special.
im a bit confused about the operation of the bush.
in the last picture ive layed it out how i think it goes.
so bush 1 is fixed to the wishbone, so as the suspension compresses the wishbone and bush 1 rotate inside of bush 2.
this means the geometry changes over bumps. wouldnt this cause bumpsteer? does the bush increase castor as the suspension deflects then?
is the aim to keep bush part 2 fixed in place in the lollypop? how is this acheved? is the friction fit of the bush enough to hold it in place on its own?
cheers boys
EDIT ive just realised the last picture bush 1 is 90degrees out
mrb27
to be honest, those bushes can all be lubed up and slung in without any alignment at all! the fact that the wishbone arm pin goes a lot further in than normal, the arm edge itself locks into the bush ensuring that it is always in the correct position. thats a wishbone bush for dummies by the look of it, no offense intended, but they are made so you simply cant get it wrong
edit: just make sure the taperd part of bush 2 is pointing towards the rear of the car
randomspeedfreak
no i understand that, my questions now are as per abovemrb27 wrote:to be honest, those bushes can all be lubed up and slung in without any alignment at all! the fact that the wishbone arm pin goes a lot further in than normal, the arm edge itself locks into the bush ensuring that it is always in the correct position. thats a wishbone bush for dummies by the look of it, no offense intended, but they are made so you simply cant get it wrong
cheers,
Matt
mrb27
yes, sorry must had a slight dappy moment there.. wouldnt be the first timerandomspeedfreak wrote:no i understand that, my questions now are as per abovemrb27 wrote:to be honest, those bushes can all be lubed up and slung in without any alignment at all! the fact that the wishbone arm pin goes a lot further in than normal, the arm edge itself locks into the bush ensuring that it is always in the correct position. thats a wishbone bush for dummies by the look of it, no offense intended, but they are made so you simply cant get it wrong
cheers,
Matt
i see your point, on standard setups the position of the offset would not move, the arm pin would be the only moving part.
but on those bushes you have is the opposite..
thinking about it, when the offset part rotates it will lift/lower the wheel going by the natural position of the offset, if the offset position was at the bottom of the bush the wheel would move toward/away from the engine. if you get my meaning. they should be ok but i would def check it out with a pro to be honest
mrb27
i also have a question about the two types of wishbone bushes, been wondering for a while what the setup differance is? i think my cabbie has the central hole in the bush, do the cars with the offset have a slightly different suspension setup? what is the best system and are they interchangeable?
