Engine Transplant
J_A_C_K_Y_D
Post Wed Oct 05, 2011 6:08 pm
Been looking for a shell and have possibly found one, I'm pretty handy with the tools and am going to hire an engine hoist, i've tried doing a search but cant find anything, dont suppose someone could point me in the right direction, is there a guide or a thread with some information/tips for this? Chances are the engine coming out will be a 4cylinder auto and a 325 manual going in?
Elliot
**BANNED**
Post Wed Oct 05, 2011 7:00 pm
Been done plenty of times,but do read Mr Mooooooooore's sticky at the head of the Engine Swaps section BEFORE plugging the engine loom in!
You will also need to remove the start inhibit circuit from the auto donor,if you are having a proper go at the donor shell and pulling the carpet out,then this is easy to trace back from the selector to the area behind the glovebox.Behind the glovebox runs a black/yellow(starter motor/ign switch)this is split by this little sub-loom,the sub-loom can be removed and the two black/yellow's plugged together.
Youth is wasted on the young.
n1tr0_9
Post Mon Oct 10, 2011 6:05 pm
You will also need a clutch pedal, master and slave cylinders, clutch line, etc etc
