Bosch Super 4 - WR78 - 2.7 build?
monkeyboy1979
Post Wed Oct 05, 2011 2:30 pm
Guys,
I've got a set of WR78 Bosch super4's from my 320 which are brand new. I'm assuming they're all good for the 2.7 application?
Cheers!
89'Schwartz 320i Coupe 2.7! m-tech2
m8782538
Post Wed Oct 05, 2011 3:30 pm
i would put in NGK, far better than the bosch plugs.
monkeyboy1979
Post Wed Oct 05, 2011 6:38 pm
More shelling out then! Thanks for the tip.
Ajsingh
Post Wed Oct 05, 2011 10:37 pm
Its been discussed on here loads, there was even a thread of a couple pages and most people recommend NGK BPR6ES plugs. Most people with 2.7s including myself use these plugs
E30 Crazy!
m8782538
Post Thu Oct 06, 2011 8:57 am
They are not expensive at all. i pay £1.82 (if memory serves me correclty) for NGK plugs
Andyboy
Alpina Colada
Post Thu Oct 06, 2011 12:04 pm
Nothing wrong with Bosch plugs at all - even the basic single electrode ones work well in such an old fashioned engine. Don't forget thoughn that thge higher the compression, the hotter the combustion so you'll need plugs to suit.
The NGK BPR6ES is a good plug, as is the Bosch W7DCR. I can't find an NGK cross reference for the WR78, but if it's a Bosch heat range 7, it'll be up to the job.
