Rear Shoes Help???
bigwinn
Post Wed Oct 05, 2011 7:52 am
Hi all
A bit of help if you can, I bought some new rear shoes for my 316i. They dont look right- I thought that they were supposed to have an arm on 2 of the 4 shoes?
Before I strip the rears out to replace does anyone think the same? Or am I OK?
They look thinner from memory too... the guy from GSF did struggle for a while saying there were two different parts available
Thanks in advance
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
Billwill
Post Wed Oct 05, 2011 8:37 am
I have just re-worked the rear drums on my 91 318i and the shoes look very different to your picture....mine do have a lever on on shoe per side to which the handbrake cable attaches.
Perhaps the levers can be removed and re-attached?
You should see the difference once you remove a drum. :?
Post Wed Oct 05, 2011 8:44 am
Those are handbrake shoes from an E30 with rear disc brakes!
Could have done with those last weekend, after spending an hour or so struggling to fit a set to my cab., before discovering that Eurocarparts had supplied E24 6 series ones!!!
12345kevin
Post Wed Oct 05, 2011 8:45 am
They look the same as the "handbrake" shoes on a car with rear disk brakes. Never seen drum brake shoes, so can't say if they are the same.
bigwinn
Post Wed Oct 05, 2011 9:03 am
nice one!!!!!
back off to GSF
thanks guys, saved me a job
Stu
