motorway breakdown HELP
spbt1
ali50ferrari
Jus gave him a call guys his car is am 325i running on early management, the vehicle is starting but dies out, the heating system is getting very hot, if any one can help im sure he would appreciate it! sorry i couldnt help you
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
DHFiS
He's moving again
StefanAnghel
What was the problem? Just in case someone else will have the same problem...
DHFiS
spbt1
Would just like to say thanks guys for calling and texting, it has been an adventure to say the least, after posting on here the car just would not have it so i called the AA, on putting the phone down to them and starting the wait i tried it one more time and sure enough it was alive. I called the AA and told em sorry pal its going again. under 3 minutes later having accelerated to 70 it went again. By this time i'm a bit fed up. Rang and booked the AA again. Piut the phone down turned they key, its alive. Pissed AA of Again. So i left the motor way without exceeding 40 and it got me 20 miles, then rejoined the motor way and drove the final 30 miles home at 70mph.
i am unsure as to whether the waterpump is functioning correctly as when i chagned the thermostat housing there was alot of crud and sludge, I need to do the belts this winter so i will change that, i think i should take the advice given previously and change the management to the newer system. Scrap Yard here we come............. this has to newk the problem once and for all.
Thamks again.
Thamks again.
spbt1
SeymourCake
when it dies, and you try starting it back up, if you have your foot on the throttle does the engine stay alive until the moment you let go off the throttle?
if so i think i had the exact same problem as you. It just randomly died out of no where. It just happened once with me, and since then I have drove 100 miles with no problem.
I personally think my issue is the fuel pump as suggested by Brian. Eitherway I will not ignore it and have to get it sorted.
It's quite scary driving a car, knowing it may break down at ANY MOMENT without the slightest clue.
Hot wire the fuel pump, so that you know for certain it's getting power at all times, leave the rear seat cushion off so that you can hear the pump clearly, and see if it is still running after the car dies.
