Inner pads wearing much faster than out pads - front brakes
clydesdale
Post Mon Oct 03, 2011 12:29 am
For starters, when I look on bavauto's site, the slide pins that I have look exactly like what they are referring to as Girling's brand of caliper. How do I confirm?
Also the inner pads are wearing way faster. The slide pins have side to side play in the caliper mounting bracket. Is the mounting bracket toast or are the slide pins shot? With the new rotors and pads in place, an some nice new slide pin lube, the brakes do twist when pressure is applied. That is what has likely caused the poor inside wear. Any thoughts on what I need to replace?
Post Mon Oct 03, 2011 8:59 am
Pins should be screwed solidly into the calliper brackets, and I wouldn't be driving any car that has movement here.
It's quite common for these pins to initially cross thread when refitting them, and there's always those who will continue to screw them home instead of unscrewing them again and refitting them straight.
A case of careful inspection needed and any damaged parts (which is likely to be both pins and the bracket) replaced.
clydesdale
Post Mon Oct 03, 2011 11:23 am
I did not explain correctly. The slide pins themselves are sloppy inside the bracket. I believe these are Girling calipers. The brackets have hollow shafts and there are threadless pins that fit in them. The bolts then bolt to the other end of the threadless pin. The bolts thread fine. The slide pins are sloppy inside the bracket.
