uneven
christo
Post Sun Oct 02, 2011 9:25 pm
Hi guys I am having problems with my 1988 316 I only drive it as a hobby car it has 52000 miles the problem is it is running uneven not smooth like when i slow down the lights in the dash light up as if is going to stop then i rev it up and on it goes again?? any ideas cheers christo.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Oct 02, 2011 10:06 pm
One of the simplest causes of this is a dying battery; it's not holding any charge so when you slow down for the lights, engine braking slows down the alternator which then doesn't generate enough juice to keep the engine going.
Take your battery to get it tested, or stick a known good spare one in for a bit to see if it cures your problems.
christo
Post Sun Oct 02, 2011 10:09 pm
Hi thanks for your reply,now i put a meter on the battery and it reads 12.80 or so thats the same as my every day car so it must be something else??
Post Sun Oct 02, 2011 11:15 pm
Air leak(s) on the inlet side, between the air meter and the engine, coupled with injectors that probably haven't been serviced in 52,000 miles.
Check the operation of the throttle position switch as well.
christo
Post Mon Oct 03, 2011 10:27 pm
Hi thanks lads for your help yes it was a air problem sorted now cheers again christo.
christo
