Hi chaps,
I bought my e30 just over a year ago and immediately took it to pieces to clean/replace/upgrade bits and left it - now I have started to put it back together - I obviously can't remember how stuff goes.
I've had the dash out and have managed to get it back in - I'm struggling with the glovebox part of it. I have no idea where the abs ecu bolts to - can't see 2 holes spaced that far apart. and the glovebox strings, catch, lid etc.
If anyone has any photo's of how it's meant to go that would be great (If i'd known I was gonna leave it this long I woulda took some!!)
Also - With regards to the seats I think someone has messed around with the mountings. Am I right in thinking that there should be two bolts coming up out of the floor about 30mm for the front mountings and 2 holes in the floor for the rear mountings that need bolts going in to to secure the seat?
Putting it back together!
James90
'88 325i Auto Chromie Cabriolet in Alpine White
Jim320i
- E30 Zone News / COTM Team
Correct with the seat mountings... You might find the runners have moved on the seat over time though if they have been knocked about a bit. Just pull them forward and line up the to the 2 bolts at the front.
Check this link out too for your dash, not sure if it will help but its a guide with how to take out and renew a dash so might have the pictures you need. http://home.comcast.net/~cdeegan9/bmw_pages.html
James90
Thought as much - for some reason someone has put a 70mm bolt in one of the rear holes (ooof!) and I cant get it out. May just try cutting it down with a junior hack saw and using a nut.
Will check it out the link cheers
James90
Had a look through the link but it doesn't have a suitable pic really.
What I'm struggling with is the ABS ECU and a funny shaped gold bracket first then I'll try and tackle the glove box etc
