Sump Gasket
tom325sport
Post Sat Oct 01, 2011 8:32 pm
I will be changing the sump gasket on my m20 tomorrow. Shall I use any kind of sealant or is it a case of cleaning the sides so they are smooth and bolting it all back together?
tom325sport
Post Sat Oct 01, 2011 8:37 pm
Engine is out the car by the way.
sweep
Post Sat Oct 01, 2011 8:38 pm
I personally would use a layer of silicone sealer on both sides of the gasket
tom325sport
Post Sat Oct 01, 2011 9:07 pm
OK thanks any other tips? Do you think silicone sealer will be a tad to strong?
**BANNED**
Post Sat Oct 01, 2011 9:08 pm
I would make sure that both faces are spotless,and use a smear of grease on both metal surfaces.
Youth is wasted on the young.
tom325sport
Post Sat Oct 01, 2011 9:10 pm
Thanks. What type of grease would you suggest please?
Mikey_Boy
Post Sat Oct 01, 2011 9:15 pm
If you fancy trying something different, you could use Loctite 518 instead of a gasket... If you have a cork gasket as your replacement, it might be worthwhile trying the loctite instead as cork gaskets are notoriously crap as soon as they are heated up and cooled down a few times. If you have a paper gasket, these are much better, and benefit from a touch of sealant either side of the gasket but I would consider ditching the gasket altogether...
Good luck!
:thumb:
Mike
**BANNED**
Post Sat Oct 01, 2011 9:23 pm
tom325sport wrote:Thanks. What type of grease would you suggest please?
Similar stuff to Castrol LM!
I too used to use a silicone type sealant,until I read a post by Ant,who commented about 'silicone hanging like snot' from a crankshaft's webs....
Any surplus grease that squeese's into the crankcase will be washed and diluted by the engine oil.
tom325sport
Post Sat Oct 01, 2011 10:11 pm
Mmmmmm....Things to think about now! Thanks for the advise
I was about to ask about silicone sealer and its effects when hot! Might leave that for now. I think grease and a gasket should be more than efficient as BMW themselves did this surely? I think they only leak/break when old.
Post Sun Oct 02, 2011 7:34 am
For a cork gasket all thats reguired is LM grease. The use a tightening sequence from the middle of the casing moving out in diagonal moves.
The problem with any silicone product is that you could end up with a bead oozing out inside the sump. If this then dislodges, and swims about in the oil, it could get lodged anywhere and starve vital areas of oil. As Malcolm says, excess grease just gets absorbed into the oil.
tom325sport
Post Sun Oct 02, 2011 9:17 am
B7 thank you very much!!! :D
Mikey_Boy
Post Sun Oct 02, 2011 11:06 am
Ok - time to weigh up the options here. Grease does get absorbed into the oil, but it really doesn't do it any good so make sure that you change your oil shortly after doing the gasket job if you go that way.
One thing is certain with a cork gasket - eventually it will leak!! NOBODY uses these any more in modern engines as they simply don't seal - they move with heat and compress so any torque you apply to the joint is immediately lost.
The only reason you get sealant in the engine is if you USE TOO MUCH! Most people make this mistake - a small bead on the centre of the joined surfaces is all that's needed to ensure a good seal along with adequate curing time - that's the other mistake people make - you need around 2 hours curing time with loctite 518. If you follow the instructions, you will have a leak free sump for years...
Your choice however and good luck whichever route you choose!
Cheers,
Mike
Post Sun Oct 02, 2011 4:24 pm
Mikey_Boy wrote:Ok - time to weigh up the options here. Grease does get absorbed into the oil, but it really doesn't do it any good so make sure that you change your oil shortly after doing the gasket job if you go that way.
Cheers,
Mike
Id rather have a cork gasket than the "modern" rubber profile gaskets on my M54! All they've ever done is go hard and p1ss oil out all over the place. I have never had so many oils stains on my drive. EVER. Mo M20 I've had has ever leaked like my M54.
Using grease should be the same as your silicone way. Just a light smear and the amount that seeps through will have no affect of the oil at all. ANY silicone that seeps through could have dramatic effects. Proper engineers use grease every time. Bodgers use silicone.
Mikey_Boy
Post Sun Oct 02, 2011 7:38 pm
Well back in the day - I did used to develop engines for Cosworth, Ilmor and Ferrari F1... Bodger? I don't think so... 8O Proper engineers now NEVER EVER use cork.
Anyway, handbags aside, point is, there are 2 (or more) ways to do this - just (trying and failing) to point out the options... :)
Best solution for a sump? STEEL gasket with a central ridge - holds bolt torque and seals the joint...
Laters,
Mike
Mikey_Boy
Post Sun Oct 02, 2011 7:50 pm
And finally - tom325sport - I hope the gasket change (whatever method you used) went well and you are happy! 8)
tom325sport
Post Sun Oct 02, 2011 8:59 pm
Thank you guys for all the advise and tips. That's what a forum is for though, people's opinions and knowledge. :)
