Couple of 2.5 M20 Questions
tom325sport
Post Sun Sep 25, 2011 10:27 pm
I have recently purchased a full 2.5l m20 engine/box/loom/ecu (facelift engine) but the loom is not connected to the engine and is in a box.
Shall I plug the loom back together to the engine before I put it into my 318i Cab? Would this be easier? Also is there a write-up somewhere that shows where all the connections go?
I have read somewhere that I would need to remove the PAS pump before I fit the 2.5 engine?
And do I need to fit the oil cooler?
Also any advice on things I should do before I put the m20 in the car?
Post Sun Sep 25, 2011 10:44 pm
Having the engine loom all connected up to the various plugs on the engine can help.
No need to remove the PAS pump when installing so long as you get the arse end of the car well jacked in the air and keep the front wheels on the ground, this gives enough extra angle, but you still need the engine & box tilted at a good old angle. No oil cooler needed.
I really would recommend fitting an E36 rack once the engine bay is empty. Fit the clio servo before putting the engine in. I always keep the inlet manifold off when fitting the engine as it's a pain in the arse to connect the heater pipes when the inlet manifold is on.
tom325sport
Post Sun Sep 25, 2011 10:54 pm
Great advice thank you! What are the benefits of fitting a e36 rack? I will be using the car on weekends/sunny days only?
Also are the coils the same on all e30's as I have one from the 318 and one with the 2.5 engine?
Post Sun Sep 25, 2011 11:01 pm
Ignore my bit about the inlet manifold and clio servo, my eyes must be playing tricks on me, I was sure your thread title said M50 :mad:
Oil cooler would be helpful with the M20
E36 rack just makes it a far more dynamic car to drive, but is a bit of faff on and a few hundred quid in bits by the time you are done.
tom325sport
Post Sun Sep 25, 2011 11:02 pm
OK I see, no worries! Thanks again. Any idea about the coils?
Post Sun Sep 25, 2011 11:05 pm
your 318i coil will do the trick, :D
tom325sport
Post Mon Sep 26, 2011 12:53 am
Great stuff! Thanks
