Please Help!
beemerstu84
Post Sat Sep 24, 2011 6:09 pm
Hi there,
I'm hoping someone can help me.
I have a 325i sport. Last week she was misfiring. So I pulled the leads 1 by 1 to trace where the problem was.
The prob was with no. 6 cylinder (the 1 nearest the bulkhead) I then changed the no. 6 lead with no. 5 - prob still with no. 6
I checked the spark plugs & changed them about. Prob still @ No. 6 still.
I then carried out a compression check. All were the same - about 150 psi.
So I changed the no. 6 injector & gave it all a good clean.
She now idles fine, but as soon as you put any load on it, she misses again.
I hav also replaced the coil, leads, plugs, distributor cap & rotor arm.
Still the same problem.
Does anyone have any ideas?
Any help would be appreciated.
Stu
asmith88
Post Sat Sep 24, 2011 9:45 pm
definatley getting spark and fuel at that cylinder?
1990 brilliant red 318 is
beemerstu84
Post Sat Sep 24, 2011 10:38 pm
When its sitting at idle its definitely get a spark & fuel. But something is breaking down when the revs are lifted.
Any ideas?
beemerstu84
Post Mon Oct 03, 2011 4:16 pm
Hi there,
Thought I would post an update on how I'm gettin on with my misfire.
I now believe its an electrical fault. I looked at the ecu & it all looks good with no damage.
So my next theory is the wiring from the ecu to the injectors. In particular the no. 6 injector.
Does anyone have any ideas which wires to check & how to go about testing them?
Stu
