suspension difference
Ninja_Penguin
im looking at suspension kits, what is the difference between the saloon and touring kits?
If you can't find a touring specific kit ones for a convertible with the same sized engine as your touring will suffice.
What are you looking at ?
You can't go wrong with Bilstein dampers and either Eibach or H&R springs - they arent cheap for a reason
Ninja_Penguin
lookin at prosport ones. £209...i cant really afford any more than that
and since they useto be Jamex, and ive had Jamex kits before i dont see a problem with them
Morat
The difference is that the Touring and Cab are heavier at the back end than the 2/4 doors. Cab is heavier, strangely enough.
parkin10
i have specific touring springs by apex 30mm dropcapri_rob wrote:If you can't find a touring specific kit ones for a convertible with the same sized engine as your touring will suffice.
but i think it looks a bit arse low
cab springs are said to work better though
oomz1975
What condition are your rear beam bushes, if they are shot, that maybe another reason for being too low & best to deal with along with the suspension.parkin10 wrote:i have specific touring springs by apex 30mm dropcapri_rob wrote:If you can't find a touring specific kit ones for a convertible with the same sized engine as your touring will suffice.
Ninja_Penguin
ah so im assuming the springs will have a slightly higher lb'ageMorat wrote:The difference is that the Touring and Cab are heavier at the back end than the 2/4 doors. Cab is heavier, strangely enough.
