Car dies problem is back
spbt1
Post Fri Sep 23, 2011 3:43 pm
So i had a major problem with the car cutting out after 45mins of driving (it was basically cutting power to the fuel pump but when i removed the blu temp sensor wire it would fire up although lumpy and incorrect) I thought i had fixed this issue by replacing the DME relay and have had 4 or so months of trouble free motoring.
Then just recently i took her for a drive and drove her a fair bit harder than i normally do 100+mph and after ten minutes...........................she died ( and as per usual after ten minutes of contemplating gettting recovery it fired up again.)
I can only put this down to a possible over heat style problem although the gauge never moves, the blue temp sensor is new the DME realy is new, Thermostat and housing is new.
I also noticed that although the temp gauge didn't go up the heaters were burning my feet prior to it cutting out.
I know we have been through this before but if anyone has any other ideas it would be most appreciated
Oh its a 325i sport tech 1
Post Fri Sep 23, 2011 11:12 pm
Failing crank sensors tend to be temperature sensitive.
groovylee
Post Fri Sep 23, 2011 11:53 pm
exactly what i was going to say brian :) a really common failing on Alfas, it would run fine until hot, then cut out. after allowing to cool for a while, it would run again. get that crank sensor changed dude, it sounds like you've tried everything else that it could be.
good luck with it :)
fixedwheelnut
Post Sat Sep 24, 2011 12:01 am
Is it still cutting power to the fuel pump? Fuel pump relays burn out and play up when hot!
oomz1975
Post Sun Sep 25, 2011 5:35 pm
Is changing the crank sensor a pretty straight forward affair?
Post Sun Sep 25, 2011 9:07 pm
First we need to find out which engine you have exactly.
The crank sensor on later 325 engines is mounted on the front right of the engine, next to a toothed wheel which is part of the crank damper.
On early engines there are two crank sensors mounted in the bell housing of the gearbox.
oomz1975
Post Sun Sep 25, 2011 9:56 pm
I have the later engine.
Post Sun Sep 25, 2011 11:08 pm
In that case, the crank sensor is held in place by a single bolt, on the front right of the block. Unfortunately, it also tends to be held be aluminium 'white rust' as well after twenty years.
The lead goes across the front of the engine behind a plastic cover behind the water pump pulley, to a plug under the diagnostic socket. It's not at all easy to remove and refit this cover with the radiator, etc. in place, but the lead will reach over the top of the rocker cover.
Post Sun Sep 25, 2011 11:15 pm
the Op's car is a 1986 Tech 1 sport, if it's running the early system which i think it is, then the ECU is likely to be the culprit,
try tapping the ECU next time it plays up,
spbt1
Post Mon Sep 26, 2011 8:23 pm
Cheers for that steve but i have on more than one occasion tapped the ECU to check if that is the case but to no avail. although on inspection the ECU does get very hot. I may have to start looking for a known working ECU and i will Change the Crank Shaft Sensors (a bit pricey too if i remember correctly and i'll need 2.)
Thanks again guys the quest continues.
And the spec is exactly as steve remembered. (awesome)
It did get a machine polish this week and a full interior Valet so, although an exspensive treat with no mechanical gains it cetainly looks like it should go well.
