M3 shocks fit 51mm struts?
martinpallot
I just bought some Group N bilstein M3 front inserts thinking that M3 shocks are interchangeable with other 51mm struts. Can someone confirm this/prove me wrong before im severely dissapointed when they arrive!
I believe they will if you have the right collars for the shocks ?
martinpallot
Thanks, I expect the group n setup will be based on the larger heavy duty insert as opposed to the skinny ones fitted to tech 1 sports which are interchangeable between 45 and 51mm housings? so in theory there should only be one type of collar for them, unless the M3 collar is different to that on a normal e30 strut?
They are like B8's but much much shorter stroke
