Non starter!!!
FMH
Post Wed Sep 21, 2011 3:52 pm
After converting my mates cab from a 1.8 to a 2.7, there is no power. No lights when the key is turned, let alone any engine turnover. Any idea what this could be.
Bought the car as a non runner, so not sure if it turned over before, but the dash lights did come on.
Any help will be appreciated.
FMH
Post Wed Sep 21, 2011 5:12 pm
Just tried + on the battery to + on the coil, lights come on in the dash, when i turn the key, the lights slightly dim, but no action
Post Wed Sep 21, 2011 7:45 pm
Need more info! Any electrics working on the car? If so, what?
Exact answers, please!
FMH
Post Wed Sep 21, 2011 11:06 pm
Nothing working at all, but when i connect the + on the coil and the + on the battery, the lights in the speedo, light up, i can then use the wipers and lights, etc.
Without that direct connection, nothing at all.
Post Wed Sep 21, 2011 11:41 pm
You are risking loom damage by connecting the coil + to the battery + and then switching things on for more than the shortest period to see if they work!!
There should be two (possibly three) wires connected to the battery + terminal, apart from the main, thick black one. One of these you should have connected from the new engine loom (with a brown/orange also going to the earth terminal on the top of the strut), and the other one goes to the fusebox.
It seems likely that this latter wire isn't connected properly, or hasn't been connected at all.
FMH
Post Wed Sep 21, 2011 11:59 pm
there is 2 wires attached to the positive terminal alongside the thick one.
is there any chance you could give me a picture of the wires which should be attached to the top of the strut and fusebox end please?
Post Thu Sep 22, 2011 12:06 am
FMH wrote: is there any chance you could give me a picture of the wires which should be attached to the top of the strut and fusebox end please?
If you knew how long it took me to put up my sig. pic., you wouldn't ask questions like that!
Look under the black outer sheaths of the wires. All the ones to the battery +should be red and the one to the strut tower should be brown/orange. You should be able to trace the red wire all the way from the fusebox, along the bulkhead. It's entirely in the engine compartment - it doesn't run inside the car.
FMH
Post Thu Sep 22, 2011 12:11 am
the 2 wires on the strut housing are connected onto the bracket where the earth cable is attached from the battery. the positive terminal definitely has the other 2 wired attached, one from the fusebox and one from the engine loom, i checked them just now.
what next?
FMH
Post Thu Sep 22, 2011 12:13 am
the car has been parked for 2-3 years, any chance of any relays being screwed?
Have you checked the colours of these wires?
FMH
Post Thu Sep 22, 2011 12:15 am
no, but matched them to my e30, look to be coming from the right places.
FMH
Post Thu Sep 22, 2011 12:19 am
i will check the colours in the morning to make sure. if its not the wiring, what could it be? saves me having to come back on here and posting and waiting.
FMH
Post Thu Sep 22, 2011 5:04 pm
Brian your a top man, got the car running, the wire from the fusebox wasn't attached, was sitting under the strut brace. Much appreciated. Thanks
