Rust around windscreen
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Sep 18, 2011 1:04 pm
I've got the smallest blister of rust on the scuttle, just on the corner of the windscreen.
I know about the sealant failing in this area, but how bad can I expect this rust to be? I know the windscreen has to come out, I'm not too worried about that, but my concern is that the dash will have to come out too...
pac1982
Post Sun Sep 18, 2011 1:21 pm
I would take the dash out anyway to aviod doing any damage to it
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
**BANNED**
Post Sun Sep 18, 2011 1:40 pm
When you take the windscreen out,you will find that the cause of this is that the drain hole in the corner of the 'screen aperture was blocked at the factory with a fabric strip....I was lucky...I was able to trim the strip back and clean the surface rust off and re-paint.
Given the state your inner wing was in,I hope that you are lucky as well!
Take the 'screen out first,if you need to take the dash out it will be easier to lift it through the 'sceen aperture anyway.
Youth is wasted on the young.
Grrrmachine
Post Sun Sep 18, 2011 4:15 pm
Bit naughty of me to steal pics from x-works' excellent M3 resto, but still...
That small hole drilled in the metal. Is that the drain hole you're talking about, daimlerman?
Post Sun Sep 18, 2011 5:20 pm
That's the drain hole.
Regarding the dash; if you leave the glove box open and just remove the two bolts that hold the dash in place (near the bonnet lever), you can lift and push the dash back enough to get something between it and the windscreen aperture metal to save it from damage.
Grrrmachine
Post Sun Sep 18, 2011 5:40 pm
Cheers for the info Brian, but mine's LHD so the steering column comes through on that side. Will that still work, or am I risking a cracked instrument cluster?
Post Sun Sep 18, 2011 5:44 pm
Can't see it will hurt the cluster. The dash should be free to slide up on top of the top column shroud a few mm.
You're only looking to get a gap of around 10mm max.
Grrrmachine
Post Sun Sep 18, 2011 5:58 pm
Yeah, anything to squeeze some metal and wood down there so that weld-splatter doesn't hurt the vinyl.
Thanks for the info guys. This job isn't immediate, but it'll be done within the next month so I need to know how to proceed.
Jozi
Post Sun Sep 18, 2011 6:40 pm
I was wondering about the drain holes, mine also has tape there, best get rid of it or just trim ir back a little?
This is not a job I would like to be doing!
**BANNED**
Post Mon Sep 19, 2011 1:00 am
Just come in from work....
Yes,as Brian says,that's the hole that I found was covered with tape.I was lucky,I was able to clean the rust off and re-paint,it looked as if the water sat in the channel,then drained via the screen seal.If I had found rot,I was not confident enough of my welding skills to replace the screen seal lip!
Kos
Post Mon Sep 19, 2011 1:06 am
worst case scenario
**BANNED**
Post Mon Sep 19, 2011 1:08 am
Kos wrote:worst case scenario
There but for....
Mine was a blister about half the size of the OP's!
Size does matter....
Grrrmachine
Post Mon Sep 19, 2011 7:05 am
Thanks Kos! I knew I'd seen it repaired somewhere, but I read skipunda's and x-works' resto threads, and hadn't got round to checking yours!
I'm really hoping mine doesn't end up like that though.
Grrrmachine
Post Mon Oct 31, 2011 5:40 pm
Just as an update:
I got the windscreen and seal out today. In the corners is some sort of sticky rubberised coating with plastic backing, but nothing visible covering the drain hole.
The rust had just made a hole in the steel, the size of a BB pellet, but I managed to zap MIG weld around it then fill it in, then ground it all down and polished it with a flappy sanding wheel. Good as new.
