are these any good
bigredbmw
- Zone Supporter
http://www.ebay.co.uk/itm/BMW-E30-Full- ... 415630069d
has anybody on here used these bushes if yes are they any good .......
bigredbmw
- Zone Supporter
E30_Crazy
That first link looks like a pretty good deal, if the bushes are as durable as implied by the add. £150 for a full set of bushes...
There are cheaper ways to ruin an E30.
E30_Crazy
Elaborate
I thought stiffer bushes were good?...
- **BANNED**
Prices are similar when postage costs are taken into consideration....
I use polybushes in some locations on my cars,I find them longlasting(never,yet had to replace one)and easy to fit,but they do transmit road noise into the car.
I have not fitted polybushes to the rear axle carrier,as I understand that they alter the way that the car behaves whilst cornering 'briskly'.Perhaps the only place on an E30 where polybushes will not affect noise levels is their use on rear trailing arms,given that rubber is retained for the axle carrier and the diff bush.
It is generaly accepted that front wishbones are better with an M3 type eccentric bush,the OE one is solid rubber and I understand can be very 'playfull' to install correctly,the poly equivilant comes in two parts and is a doddle to install.
Youth is wasted on the young.
Barx325i
bmw know more about suspension design than most peopleE30_Crazy wrote:ElaborateI thought stiffer bushes were good?...
If you're putting a car on the track and you want it mega stiff, that's another thing..
- E30 Zone Meets/Events Team
I have powerflex bushes all round on the cab, and they've been on there for about 3 years.
Nothing has rattled, cracked or fallen off, as so told by others on the zone.
So a plus from me on them.
Barx325i
yeah and necessary to take the extra weight from your megadonkRav335uk wrote:I have powerflex bushes all round on the cab, and they've been on there for about 3 years.
It's still on the road BarclayBarx325i wrote:yeah and necessary to take the extra weight from your megadonkRav335uk wrote:I have powerflex bushes all round on the cab, and they've been on there for about 3 years.
Barx325i
just gives me more time to work on the lotusRav335uk wrote:It's still on the road BarclayBarx325i wrote:yeah and necessary to take the extra weight from your megadonkRav335uk wrote:I have powerflex bushes all round on the cab, and they've been on there for about 3 years.
Grrrmachine
- E30 Zone Wiki / Team Member
Not quite sure if 150 quid is a good deal or not. To buy all the parts for the rear beam, using new bolts and Lemforder bushes, works out at 112 quid over here. It's possibly cheap for the exchange rate, but I have no idea what those parts would cost in the UK.
E30_Crazy
I'm used to the horrible exchange rates (US $ to £). Usually sits around 1.6-1.7, but in the summer it can get as bad as double!
nickso
- Location: Go do that voodoo that you do so welllllllll!!
Make sure the metal bits are stainless steel too. some of the cheaper ones aren't I think.
'88 e30 328i M52 track bint.
Read this before you fit: http://www.e30m3project.com/e30m3perfor ... iction.htm
