Anyone who's replaced seat elements ...
Cloggy Saint
Post Fri Sep 16, 2011 7:00 pm
I've done this a couple of times in the past and always put the heater elements loose on top of the padded layer and then the outer cover over the top. This was how I first found the seat and so did the same. I've since stripped a seat where the padded layer and outer cloth were stitched together along the 3 stitch lines that run the length of the seat cover, again with the elements inbetween. Is this how they left the factory? Is it really necessary to unpick all the stitching to replace broken elements and then sew it all up again? What have other people done?
nickso
Post Sat Sep 17, 2011 12:27 pm
All the ones i have removed have been in between the stitching.
'88 e30 328i M52 track bint.
Cloggy Saint
Post Sat Sep 17, 2011 2:08 pm
So to replace damaged elements you have to feed it through the channels between the stitching?
mattycoops43
Post Sat Sep 17, 2011 3:15 pm
I would guess so, not had much to do with heated seats, but I have ordered a brand new seat cloth cover, and it comes ready sown to the padding. Must be able to be fitted without taking it apart.
1990 325i se "weinrot"-How did they know?
Cloggy Saint
Post Sat Sep 17, 2011 3:33 pm
Thanks. The next dull seat cover related question, what colour should the 3 lines of stitching be on an anthracite seat?
