Odd question but does having the car in D (holding it on the footbrake) as in traffic affect the cooling compared to being in N or P with the handbrake up?
I only ask as on occasion when stuck in traffic, I've noticed the temp gauge sneak up just past half way.
This has always bugged me, so on returning home I left the car sitting at idle (P/handbrake) for a fair old time and it never gets close to half way, even after prolonged periods.
As such, I put kept the handbrake on, stuck it in D and the temp started to rise slightly. Back to P and the temp started to fall slightly. (I don't think it had anything to do with the viscous coupling/aux fan)
WTF?
Iirc, the car seems to idle higher in N/P rather than in gear. Would that make a difference?
Any opinions gratefully received.
Car in D vs N or P - affecting cooling?
George
Sold: 1986 E30 325i Cabriolet, Alpine White
hongkongfuey
- Mad-tango-geezer
it will make a difference, if you put in d, and let the brake off car will go forward, so with the brake on its under strain, as if on a manual riding the clutch before pulling off.
and under load the car will idle slower, so in n or p it will be normal idle
hope that helps
hope that helps
with cars like mine,
cecotto479
- Caution Unreliable Seller
Don't leave it running for more than a few moments in "N" or "P" or you may have more to worry about than the temp gauge rising a fraction, George. Not good for the gearbox.
1981 E23 735i
Andyboy
- Alpina Colada
^^^This. It eventually buggers the forward drive clutches.
How old is your viscous coupling?If it looks old and grottly, invest in a new one.
- Homo Hair
By taking it out of D when sat?Andyboy wrote:^^^This. It eventually buggers the forward drive clutches.
blingsta
- Boost Junkie
letting the car rund/idle in N or P is like a car idleing in neutral? hows that bad for the forward gears on a auto box? leaving it in D with your foot on the brake is worse!! damages the torque converter..
cecotto479
Oh well, you'll know best. I'll take my chances with the torque convertor thanks.
Check what you post as fact next time though, someone might take you seriously.
1981 E23 735i
- **BANNED**
I do not own an auto E30,but I understand that letting an autobox vehicle idle in N or P alters the way the gearbox oil circulates.
Some years back when I was bus-driving,we were instructed NEVER to idle Renault minibuses in P,because that was the prime cause of autobox failure...
We did not like the driving position on the Renault minibuses.....
Youth is wasted on the young.
- Homo Hair
From the manual.. So when in traffic put it in N, according to BMW.
Also, never sit there giving it big rev ups in neutral or park as that shags the box over time also
Andyboy
- Alpina Colada
Errr, no............blingsta wrote:letting the car rund/idle in N or P is like a car idleing in neutral? hows that bad for the forward gears on a auto box? leaving it in D with your foot on the brake is worse!! damages the torque converter..
Firstly, the 4HP22 automatic gearbox develops wear in the thrust washers between the oil pump and the forward drive clutch. In N or P this allows a cross leak from the pump to put slight pressure on the forward drive clutch. This tries to engage it slightly, but whilst it doesn't have enough pressure to move the car, it starts to heat up the clutch rings which are slipping. Enough heat, and they will get too hot and fail.
Jack up an old E30 auto, put it on stands, fire up the engine and let it idle in N with the handbrake off. 9 time out of 10 the rear wheels will start to revolve slowly - that's the drag in the autobox. It's good practice to do this when working on the car when the engine has to run for extended periods.
5 mins in traffic probably won't hurt it but neither will leaving it in D. If the idle speed is correct, the handbrake will hold it (assuming that works as it should).
Leaving it in D will not in any way 'damage the torque converter'. These have what's known as a 'stall speed', the point at which the unit locks up. Put yours in D, foot on the brake and press the throttle - the point at which the engine will not rev any more is the converter stall speed. At idle, the torque converter is quite happy to sit there and do nothing.
Hope that helps.
