ive broken the rubber boot that covers the joint on the strut end of the front wishbones.
ive looked on bmw fans and its not listed. does anyone have any ideas of where i could get one? (or a whole joint?)
and also does anyone have any ideas for the nyloc nuts used? one one m14 one m12.
cheers,
Matt
rubber gromit on wishbone (bottom of strut)
randomspeedfreak
clarko74
I had this problem a while ago, afaik you can't get the rubber boots on their own from BMW.
I was all set to buy a new ball joint to put in but the fella at my local garage said that I should be able to buy the rubber boots on their own so had a look around and bought these: >>clicky<<. As it says in the listing they do indeed fit the control arm ball joints perfectly.
Are you looking for the nuts for the ball joints? I get mine from BMW, last time I bought the ones for the control arm to strut ball joint they were less than 50p each, although that was about a year ago.
clarko74
randomspeedfreak
you're a hero.clarko74 wrote:I had this problem a while ago, afaik you can't get the rubber boots on their own from BMW.
bmw fans say the nuts are discontinued but i dont believe that. ill get onto bmw to check.
Thanks mate
asmith88
last time i checked bmw told me they where discontinued but they found one some other way that was the same,
1990 brilliant red 318 is
