stokiedundee
Post
Mon Sep 12, 2011 9:22 pm
Hi fellow zoners. I have a 1989 bmw 316i E30 and sometimes when I drive her, the clutch pedal sticks to the floor and then I pump the pedal a couple of times and its ok again. Also the biting point feels slightly high near the top. I manage to change gear sometimes without a hitch but sometimes I have the sticking problem come back, and its been dangerous for me a couple of times when its been like this because I couldnt put her in the right gear whilst I was driving. I dont want to buy a new clutch if its just a seal or cylinder or something. But I aint no mechanic and am clueless. Can anyone help me please and is there any things I can do to rule out the clutch being worn? Any help will be much appreciated.
Thank you.
Ryan.
Chimmychanga
Post
Tue Sep 13, 2011 7:53 am
Sounds like the problem that I've just had. My pedal didn't stick to the floor but had no pressure. After a couple of pumps (or more sometimes) the pedal would have some pressure behind it and work. I replaced the master and slave cylinders and its all good again now. I was advised to replace both at once as a new master would probably make the slave fail in the near future.
Its a pretty easy job to do yourself, my biggest problem was getting the gearbox shield off the bottom of the car! Each cyl was £30-40, some new brake fluid and some aquarium pipe for bleeding the system. (I got the parts from 123SpareParts.co.uk and they were febi bilstien)
stokiedundee
Post
Tue Sep 13, 2011 9:41 am
Chimmychanga wrote:Sounds like the problem that I've just had. My pedal didn't stick to the floor but had no pressure. After a couple of pumps (or more sometimes) the pedal would have some pressure behind it and work. I replaced the master and slave cylinders and its all good again now. I was advised to replace both at once as a new master would probably make the slave fail in the near future.
Cheers mate. I would'nt be able to do it myself because my diy mechanic skills are pretty poor!!! If I was to get a new clutch fitted instead would that come with the slave and master cylinders or are they a different part alltogether. And do you know anywhere honest where I could get a free diagnosis of what the problem is?
Thanks.
Ryan.
Post
Tue Sep 13, 2011 9:49 am
Your problem is the main seal inside the clutch master cylinder.
There is nothing in your post to suggest that your clutch is in need of replacement.
It is true that if the master cylinder is replaced, there's a good chance that the slave cylinder will fail shortly afterwards, as a result of its piston being pushed slightly further than it has been recently and damaging the already fragile seal.
Replacing the two hydraulic cylinders is a completely separate job from replacing the clutch.
stokiedundee
Post
Tue Sep 13, 2011 10:33 am
Thanks Brian. My mate is going to fit me new cylinders in 2 weeks and a new clutch because he's doing it for me at a great price so I just decided to have a new clutch aswell in the end. Then it will be like driving a new car hopefully!
Thanks for you help mate.
Ryan.
BenHar
Post
Tue Sep 13, 2011 6:23 pm
Sometimes you've got to wonder why people bother to ask for advice on here.
Ben
