Miss-behaving indicator - learn from my mistake!
FEP
Post Sun Sep 11, 2011 4:26 pm
Having spent a number of hours pulling my car and loom apart trying to fix the front n/s indicator I hope that others can learn from what happened to me.
The bulb was good and my multimeter showed decent voltage at both terminals of the holder.
Having previously been the recipient of the wisdom of Brian Moore on this subject, I understood that decent voltage did not mean that adequate current was getting through. The problem is exacerbated by the fact that the current is not continuous - the multimeter doesn't react quickly enough to show the actual voltage.
I then discovered that both wires had continuity to earth and so began the relentless search for a short circuit on the live (blue with red) wire. As it happens my carpet was already out but out also came glove box, fuse box, instrument panel with no evidence of a short any where.
I was referring to my Bentley manual and could not / do not understand why the blue with red wire seems to run of down the loom that runs to the boot down the n/s side of the car. Then found another blue with red going down the same bit of loom - I could only assume that the wire goes a short way down that bit then comes straight back out - WHY?
Then I realised what the Bentley (being American) does not show - the n/s front wing repeater (absent in US cars) runs in parallel off the loom behind the glovebox. I unplugged it and the short was gone. Ah!! Seems that the resistance of the bulb is low enough to register as continuity. Pulled the wing repeater out and cleaned up the terminals put it all back together and that seemed to fix the front indicator.
What I really don't understand, given that the wing repeater is in parallel, is how bad contacts there would stop the front indicator.
All I have to do now is try yet again to figure out why fuse 10 keeps blowing.
**BANNED**
Post Mon Sep 12, 2011 12:53 am
Indicator repeater is part of the dash loom on RHD,perhaps explains why it is in parallel?
Fuse 10,does it blow after selecting reverse gear?
Youth is wasted on the young.
FEP
Post Mon Sep 12, 2011 7:03 am
daimlerman wrote:Indicator repeater is part of the dash loom on RHD,perhaps explains why it is in parallel?
Well yes, it comes of the loom on the dash side of the connector block behind the glovebox. But why does the blue with red wire apparently run off down towards the boot then return and given that the wing repeater is in parallel, how would rusty contacts cause the front indicator to stop working?
daimlerman wrote:Fuse 10,does it blow after selecting reverse gear?
Nice thought Malcolm, but no and having just done an engine change and renewed all the gearchange bushing, that wire is fine and properly secured.
**BANNED**
Post Mon Sep 12, 2011 6:36 pm
Usual and obvious cause of fuse 10 popping!
Leaves you with the misery of un plugging each item on the circuit in turn to trace the culprit,what deep joy!
My money would be on the circuit board in the cluster,for what it's worth....
FEP
Post Wed Sep 14, 2011 6:31 pm
To be honest, it sometimes goes for weeks without going (then goes three times in a week) so I'll have to wait till it's more consistent before unplugging things.
Still totally confused about the front indicator. :mad:
genozide
Post Thu Sep 15, 2011 11:06 am
Reverse switch faulty can cause Fuse 10 to blow...Had similar issues with my E30 until I traced them down to the reverse switch...replaced the switch and the problem is solved.
