Headlamp Wiper motor refurb
Post Thu Sep 08, 2011 8:03 pm
Is there a "best" way to do this ?
I had the headlamp assembly out of the drivers side of the turd today and the backplate on the motor appears to be just clipped in place - by about 10 plastic clips which are sure to break when I try and lever it off :x
It it necessary to have the backplate off ? - or will blasting WD40 down the spindle and just operating them get them working again ?
Post Thu Sep 08, 2011 10:13 pm
Absolutely necessary to have the back off and strip it down.
Clips won't break if the plastic is reasonably warm, as it will be in summer (!!!!!!!!!!), and if they do, large cable ties will replace them.
Post Thu Sep 08, 2011 10:27 pm
Ok so once I get the back off is it just a case of clean/WD40/Oil any bits that look like they should be moving ? Is there any way of testing the motors off the car ? the plugs appear to have 4 pins in them :?
BenHar
Post Thu Sep 08, 2011 11:47 pm
leeparkes
Post Thu Sep 08, 2011 11:55 pm
Does it damage the motor if they have been trying to run seized up?
Rob you will be lucky if you dont break any clips :)
Post Fri Sep 09, 2011 12:04 am
leeparkes wrote:Does it damage the motor if they have been trying to run seized up?
No, there's a positive coefficient resistor (a round grey disc) inside the units that protects the motor.
rover-2000
Post Fri Sep 09, 2011 6:19 am
Watching this with interest as I have to do the same on ours. I have a spare set of motors here courtesy of another Zoner, so I'm going to strip them and refurb, then just swap onto the car.
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
Post Fri Sep 09, 2011 7:26 am
Brilliant :cool:
Really should check the wiki more often :o:
