Steam from M20
retroboyo
Post Thu Sep 08, 2011 7:07 pm
Today wasnt a good day. Work was bad, fell out with a girl and driving home steam was coming from under the bonnet at the traffic lights. It had used a bit over 1 litres in coolant and steam is coming from below the exhaust manifold at the rear. Is this the head gasket, cylinder head or both.
**BANNED**
Post Thu Sep 08, 2011 7:31 pm
If it's got tits or wheels..... :o:
Remove the oil filler cap and report what you find,a mayo-like substance is not good news.
Same with the radiator header tank,check for any signs of water/oil mixing.
I doubt that this is 'just' a head gasket,my feeling is that a waterway over the exhaust port has corroded....
Youth is wasted on the young.
retroboyo
Post Thu Sep 08, 2011 7:34 pm
Thank you for the feedback, much appreciated and I will check.
Post Thu Sep 08, 2011 7:47 pm
There's a heater hose that comes out from the back of the head. Because of it's location it leads both a hard life and tends to get neglected.
The bolt on alloy connector for it has also been known to corrode.
If you're lucky, one of these is what's failed.
Ajsingh
Post Thu Sep 08, 2011 7:56 pm
There is a coolant pipe at the rear of the head... Check that also
Edit: what brian said ^^^ :)
E30 Crazy!
retroboyo
Post Thu Sep 08, 2011 9:06 pm
Will check thank you
retroboyo
Post Sat Sep 10, 2011 5:46 pm
There is a fine jet of water coming from where the head meets the block. It is spraying onto the exhaust manifold which is causing the steam, although the engine wasnt fully warmed up when I was checking. Its below the rear most exhaust port and there is what looks like a water way prutruding slightly out running up the block into the cylinder head at that point. No Sign of any gunk on oil filler cap or in coolant expansion tank.
**BANNED**
Post Sat Sep 10, 2011 6:40 pm
Looks like the head will have to come off for examination.
My money is on a corroded waterway above the exhaust port.
The only good news is that these can usually be welded and ground back flush.
retroboyo
Post Sun Oct 23, 2011 3:30 pm
Hi
Finally got around to taking the head off.
This is where it was spraying coolant from below the exhaust manifold on the rear piston. There is a crack in one place striaght through it and the other bit looks frayed around the hole.
There is coolant sitting on some of the cylinders, dont know what that means.
The cylinder looks normal, cant see any corrosion where it was leaking or anywhere else on it.
Any advice on what I should do next would be appreciated.
craigieeb
Post Sun Oct 23, 2011 4:51 pm
Clean it up,
stick a new head gasket on
Job done i reckon
Andyboy
Alpina Colada
Post Sun Oct 23, 2011 6:11 pm
Get the head skimmed and pressure tested. Do not skimp on this. Clean up the block with a scraper followed by 240 grit went and dry with a rubber rubbing down block until it's squeaky clean. New torx head bolts (if the old ones are 17mm, bin them - but keep the washers!) and a decent gasket - Reinz or Payen are both good.
mrb27
Post Sun Oct 23, 2011 6:24 pm
wouldnt be so keen to skim the head imo, unless you cooked it. by all means clean/pressure test but only skim if you rely must. if you do skim you may well need a thicker head gasket.
ofc correct me if im wrong guys but skimming is not something that should be done unless there is no other way forward.
Andyboy
Alpina Colada
Post Sun Oct 23, 2011 6:31 pm
Nope. You MUST skim the head - even if it's only 5 thou to clean up the surface. It's standard practice and the only way to get a 100% true head face.
Post Sun Oct 23, 2011 7:49 pm
mrb27 wrote:wouldnt be so keen to skim the head imo, unless you cooked it. by all means clean/pressure test but only skim if you rely must. if you do skim you may well need a thicker head gasket.
Completely the wrong advice mate I'm afraid. :)
Alloy heads ALWAYS need a light face off to ensure they are perfectly true before bolting down. I'd maybe risk an old cast iron head like an A serioes but never an alloy head.
Andy's on the money here. Take the head to a machine shop, Ask them to pressure test it and it it tests okay, tell them to go ahead and skim the minimum amount needed off. Then when I pick them up I always ak them how much was taken off for future reference..
mrb27
Post Sun Oct 23, 2011 8:24 pm
well i did ask to be corrected if wrong so no worries :wink:
my anti skim attitude comes from back when i wanted my head skimmed when i built my 2.7 lump, i took the head to a machine shop for the skim only to be quizzed on why i was getting it skimmed, i told the chap there was nothing wrong with it, no overheating etc, that i just wanted it all to be perfect and a proper job.. he skimmed it but not before advising me not to do it for resons that did make sense.
to me anyway winkeye
retroboyo
Post Mon Oct 24, 2011 12:24 pm
Thanks everyone
retroboyo
Post Tue Nov 01, 2011 8:56 pm
How the heck do I get the bolt off the end of the crankshaft
**BANNED**
Post Tue Nov 01, 2011 9:02 pm
retroboyo wrote:How the heck do I get the bolt off the end of the crankshaft
Why?
But....
Remove the undertray and radiator.
Using a 22mm socket and your longest breaker bar supported on a lump of 4+4 timber,spin the engine on the starter motor....
retroboyo
Post Tue Nov 01, 2011 9:22 pm
Sorry, I thought I needed to take the bolt off to change the cambelt, can it be done without taking it off
HairyScreech
Post Tue Nov 01, 2011 9:24 pm
yes, its just a bit of a fiddle to get it out the gap.
**BANNED**
Post Tue Nov 01, 2011 9:37 pm
retroboyo wrote:Sorry, I thought I needed to take the bolt off to change the cambelt, can it be done without taking it off
You just need to take the pulley off the end of the crank.It's hard to see or even feel,but there are 6 bolts with a 13mm head to come out,but they have locking tabs that need knocking back first.
Then the toothed wheel will come off,it's on a taper so belt it with your hammer at the exhaust side,then you will be able to remove the alloy lower cover,followed by the belt.
