Dash lights faint
ali50ferrari
Post Thu Sep 08, 2011 2:27 pm
i may sound a bit dim ma self but have you adjusted the dimmer switch on the actual light switch??
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
Barx325i
Post Thu Sep 08, 2011 2:58 pm
ali50ferrari wrote:i may sound a bit dim ma self but have you adjusted the dimmer switch on the actual light switch??
rotate the light switch clockwise, et viola..
Barx325i
Post Thu Sep 08, 2011 3:59 pm
Could well be a faulty dimmer, not allowing full current
Post Sat Sep 10, 2011 12:39 am
Pull out the rear ashtray, and then lift out the bulb holder and bulb behind it.
Short the brown/white wire to earth with the lights on.
Post Sat Sep 10, 2011 7:56 am
diable wrote:do the dash lights dim or go brighter?
hopefully will have time to do it tomorrow
I think Brian is say that they should do brighter if the Dimmer is faulty???
