Earth Strap Q
TouringMatt
Post Wed Sep 07, 2011 8:27 pm
Did my engine mounts the other day and noticed the strap that runs to the sump looked past best, did some searching on here and keep finding mention of an earth strap being connected at the engine mount.
How many should there be and where should they/it be connected?
Post Wed Sep 07, 2011 11:00 pm
Just the one, and it's position varies with model.
If you have a four cylinder car, the engine simply won't start if the cable is defective, or will crank sluggishly. With a six cylinder car, you burn out the engine loom, as the oil level sensor wire provides a parallel earth, and this wire, not unsurprisingly, objects to being asked to carry starter motor current.
TouringMatt
Post Wed Sep 07, 2011 11:27 pm
Thanks for the reply Brian, will get the current one replaced before i use the car again, its was in a bit of a poor state!
