Hi,
I'm trying to source the rubber boot which sits between the AFM and throttle body on my 1988 325. The part no. is 13711726205. BMW dealers tell me this part is no longer available. Any ideas, ideally for a new one.
Rubber boot for 325
Try this:
13 71 1 708 800
13 71 1 708 800
Rtaylor2208
Just bought one a few months back from my local steeler, should be readily available.
Martin123
Hi both, sorry for the late thanks as I've been away. The boot I need has two outlets, one outlet for the ICV and another for the booster. I've had two sent me (1726325) by two dealers which have only the ICV outlet and both said the part number had been changed to the above. Brian does your part number have the two outlets?
Martin
Martin
Martin123
Hi Brian I've just had a look at a pic of 708800 but I'm afraid the outlets are not in the positions of the one I need. Just as the boot meets the AFM an outlet goes off to the ICV and diagonally opposite another goes off to the brake servo. Any help much appreciated.
Martin
Martin
Do you have a T shaped or L shaped idle control valve?
Do you have a branch coming off the air hose in question, going to a complicated twin non return valve for the brake servo?
