Guys
Took our Touring for a night time run and noticed that several things on the dash don't light up:
HRW switch (Lights when pressed, but otherwise dark)
No lights at all on the headlight/fog switch panel
No light on the hot/cold heater dial
Should these all be lit or not?
Dash lights-should these be lit?
rover-2000
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
- **BANNED**
HRW,no,but can be adapted in the same way as the hazard switch...but I cannot remember how!
Yes,but it's a bugger to fit,easiest way for a virgin is to take the cluster out,the bulb holder slots into the orange mask thingy.These should be on with the ign,but I usually modify them using a redundant 'headlight adjuster' internal light so that they are on with the lights.
Heater temp light is top left behind the dial,easiest way in is to remove the clock,if yours is an analogue one,if it's a digi OBC you need to remove the heater panel!
(let me know which you have and I can try to explain....)
Youth is wasted on the young.
rover-2000
Thanks for the quick reply! Ours has an analogue clock so that should be easy to do. Regarding the headlight switch, do I remove the whole panel, and what's the best way of doing it to avoid damage?
Thanks very much.
Thanks very much.
Kind regards
John
1989 320i Touring
John
1989 320i Touring
BenHar
I did this at the weekend. You can get your finger tips to the light bulb from underneath if you remove the kick panel. It's a bit fiddly but not to tricky even with my stumpy fingers.Regarding the headlight switch, do I remove the whole panel, and what's the best way of doing it to avoid damage?
Ben
- **BANNED**
This the light switch viewed from under a spare dashboard
Bulb is between the two switches,see the orange shield?,but the easier way in is to take the cluster out and look for the wire feed,pull(gently!)swap the bulb and fiddle the thing back home.
Lift the facia from the clock face.
Remove the clock towards you,by squeesing the tabs top and bottom,clock harness unplugs from behind if needed.
Panel from behind,certain that the bulb fits where my finger is!
rover-2000
Brilliant-thanks. I will give it a go. If I do have to take the lamp switch panel out, are those the retaining nuts in the pic?
Kind regards
John
1989 320i Touring
John
1989 320i Touring
- **BANNED**
Yes,the two 10mm one's top and bottom.
My mitt is around the foglight switch....
