Hi all, I have a 1989 bmw 316i and its never had an aftermarket stereo in it so it still has the old pioneer cassette player/radio in it. However I would like to put my aftermarket stereo in and take the old stock stereo out. The only problem is I dont know where the wires go? Does anyone have a wire diagram?
Thanks.
Ryan.
can anyone help me please?????????/
stokiedundee
Kos
when you remove your old one, mark the wires and connect them to an ISO block, then should connect yo your new HU
stokiedundee
Hi mate, thanks for your reply but its one of the old pullout pinoneer stereos that were installed when the car was brand new. There is no block just loads of wires underneath. I will upload a picture because I cant explain it!
Ryan.
Ryan.
The radio loom you have plugs into the accessories socket behind the LH rear corner of the glovebox. Aftermarket looms are available with the correct connector for the accessories socket on one end and an ISO connector on the other.
Note that the speaker wires (twisted pairs or parallel twin) are separate from the main looms anyway.
If you have an electric aerial there will also be a white wire coming from the glovebox direction which needs 12 volts fed to it to raise the antenna, and zero volts to lower it.
If your new radio has speed controlled volume, this is a plain blue wire that comes from a socket on the instrument cluster, directly under the speedo.
All the radio wiring on your car would have been installed by the supplying dealer, as radios were not a standard fitment.
stokiedundee
Hi mate, I found the wiring now. Do you know what iso connector I need to get because I looked on ebay and there several different ones. Please could you let me know if you know mate.
Thanks.
Ryan
Thanks.
Ryan
