Won't fire without OBC loom
milescook
Post Sun Sep 04, 2011 6:45 pm
So I disconnected the OBC and tried to start the thing, no probs. Splendid! I'm converting the car for track use so stuff like the OBC is being sold http://www.e30zone.net/modules.php?name ... c&t=204434
However, when I took out the loom its attached to a box above the control unit, and without it all plugged in she turns over but does not fire.
What is it? Something important I'm guessing! When I plugged the OBC loom back in and the box - it goes from the passenger side to this box on the drivers side, she fired up.
Here is the loom itself:
I've sold the OBC and loom, now wondering if I need to keep the loom or just the box and do some bypassing. Can someone explain how I can do this?
May have been a bit of a 'tard I'll admit, but I'm learning!
Many thanks.
Brian28
Post Sun Sep 04, 2011 7:33 pm
A couple of wires to be looped behind where the glovebox used to be. It's something like two greens, or a green and a green/black. If nobody comes along shortly with the correct colours I'll have a shufti at mine in the morning.
Post Sun Sep 04, 2011 10:42 pm
I'm sure Brianmooore will be along to help out. :cool:
Post Sun Sep 04, 2011 10:47 pm
Two green wires hanging from the loom above the middle of the glove box, going to a two pin socket.
Looking at your pic., I don't think you've removed all of the OBC loom yet, so there will still be a plug pushed into this socket with a green and green/red wire going to it.
If this is for track use, cut the socket off that has the plain green wires, and join these two together.
milescook
Post Sun Sep 04, 2011 11:34 pm
Cheers guys so far. Still confused sorry! :mad:
In the pic above, 1 and 2 are close up here:
Now, on car there is
Further down these wires...
1 (2 green wires) was plugged into 2 (green and green/red), so I should just join the two greens on 1?
As for the rest, if I haven't got all the loom yet, those wires seem to go through into the engine bay, I need them as well? Any top tips for digging them out, and what to they plug into? Also, what is the black box in the first pic in the first post, also do I need it?
Cheers for listening to many questions, am off to bed!
Post Sun Sep 04, 2011 11:42 pm
Cut off plug 1 and join the two green wires together.
The wires in your hand are all part of the OBC loom, as is the loom that goes through into the engine compartment. It goes to the alarm horn and the exterior temp. sensor, both in the area behind the LH foglamp.
Big black box is largely empty, apart from a couple of small relays in one corner. These are for the immobiliser and the alarm horn.
Note that the LH column stalk is also part of the OBC kit. It has a button on the end of the stalk that toggles the OBC through its functions.
milescook
Post Fri Sep 09, 2011 3:12 pm
Ah bejesus, cheers for the help... but that extra bit of loom is a nightmare to get at! (For my novice hands anyway). Temp sensor and aram horn wires now back to behind the fuse box, have to work out how to get them completely out through from the dashbaord, any tips?
Then the LH column stalk :( didn't realise this would be such a big job! Live and learn...
Tried joining those two green wires and firing, no joy but I think the battery died a bit too quick, so I'll try and battery jump start it tonight.
Ton confirm, I don't need that relay box and any of the OBC stuff for the car to work normally?
Many thanks again.
**BANNED**
Post Fri Sep 09, 2011 3:55 pm
milescook wrote:
To confirm, I don't need that relay box and any of the OBC stuff for the car to work normally?
No.
In effect,the relay box splits the solid green wire that runs from the ign switch to the coil.
Youth is wasted on the young.
milescook
Post Fri Sep 09, 2011 4:06 pm
Ahhh, that makes sense *why* it turns but doesn't fire.
There's an alarm on the car, I'm guessing factory fitted rather than aftermarket because of it's link with the OBC? I'm not sure, but will this interfere with anything also? I'm guessing as some sort of immobilising function? I will be removing this as well - eventually!
**BANNED**
Post Fri Sep 09, 2011 4:25 pm
Trace the alarm wires to their source,those that formed a 'loop' into the main harness will become clear.Then you can restore the cut ends.
Alarms seem to slice into things like the solid green mentioned above,or the black/yellow starter signal,or even the green/violet fuel pump feed...all of these run through the area behind the glovebox,an alarm fitter's paradise!
milescook
Post Fri Sep 09, 2011 8:02 pm
Sounds a nightmare! Fortunately thanks to the advice here I have the loom out, the car fires with those green wires joined,and the buyer will send me his plain old stalk. Hope the above helps someone else,choeers guys!
