If i blip the throttle when idling, the revs will decrease slightly, and then make an effort to rise.
However, if i disconnect the AFM, it becomes a lot more responsive to me blipping the throttle, and will rev right away. However, as expected, it does not rev hard with no AFM and is obviously undriveable.
Just wondering if i need a new AFM? Is there a way i can test it with a multi meter?
Dodgy AFM? 325i
Ajsingh
Mine does the same :s
E30 Crazy!
AFM is tested by connecting a 6 or 9 volt battery across it and measuring the voltage on the wiper terminal as you slowly open the flap by hand. Voltage must always rise as the flap opens.
A set of recon. injectors, all the air leaks dealt with, and the TPS set up properly, will cure the majority of these and similar faults on E30s.
