I think I know the answer already...
Cloggy Saint
Post Sun Sep 04, 2011 3:20 pm
... but is my diff' carrier bush fooked? And if so what problem if any would that cause?
320Touring
Post Sun Sep 04, 2011 3:24 pm
You'd get a knock/shudder from the rear end, when putting on power, or letting off.
and yep it looks goosed!
Cloggy Saint
Post Sun Sep 04, 2011 3:37 pm
Thanks for the quick reply, is it a pig of a job to replace?
pac1982
Post Sun Sep 04, 2011 4:04 pm
quite easy once its off if you have a big vice or a press
1990 BMW E30 318IS (Sold)
1990 BMW E30 316i (RIP)
Cloggy Saint
Post Sun Sep 04, 2011 4:23 pm
The entire diff' needs to be removed?
rrs
Post Sun Sep 04, 2011 4:47 pm
If you drain the diff down you could just remove the backplate. I would support the diff on a trolley jack first.
Cloggy Saint
Post Sun Sep 04, 2011 4:57 pm
Nice one, thanks for the tips!
Post Sun Sep 04, 2011 6:05 pm
Don't attempt to remove the bush in situ, and make sure all around the bush is well supported when you press the old one out or the new one in, or you'll be in parts wanted looking for a new rear cover.
Steel bush in alloy frame, so heat helps.
Cloggy Saint
Post Sun Sep 04, 2011 7:57 pm
With my record I should probably just buy the new back plate before I start!
chinna
Post Sun Sep 04, 2011 8:05 pm
sorry to hijack the thread but would the shudder be constant or appear at a certain speed, would it cause a vibration through the whole car.
**BANNED**
Post Mon Sep 05, 2011 5:21 pm
chinna wrote:sorry to hijack the thread but would the shudder be constant or appear at a certain speed, would it cause a vibration through the whole car.
This bush forms one of three mounting points for the rear suspension/subframe....
So wear to the extent shown will cause a knock power on/off,and quite possibly brown trouser moments when cornering with 'enthusiasam'....
OP,what condition are the axle carrier bushes in?
Youth is wasted on the young.
Cloggy Saint
Post Mon Sep 05, 2011 5:46 pm
You mean Beam bushes? They were replaced about 2 years agao so they should be good.
**BANNED**
Post Mon Sep 05, 2011 5:52 pm
Cloggy Saint wrote:You mean Beam bushes? They were replaced about 2 years agao so they should be good.
Ah...
Just concerned that the diff bush may have caused the beam to waggle about,buggering them,as well!
Post Mon Sep 05, 2011 6:00 pm
Getting the old one out is easy - if it's knackered anyway, just use a hacksaw or padsaw to cut through the steel outer band, taking care not to cut into the alloy housing.
Cloggy Saint
Post Wed Oct 12, 2011 6:32 pm
Only just got the new bush from the dealer (top service), and the bolt hole is quite a way off centre, but the picture of the bush in the guide I've looked at has it in the centre. Is there a right or wrong here? :?
