my cabby is a manual 89 preface lift m20b25.
why would the handbrake signal (P) on the dash display not light up any more when the hand brake is applied? cant even remember if it worked. . . .
took off the gator cover on the handbrake and that wire attached there seems fine, what else could it be it doesnt affect the drive of the car or anything but i just like little niggly things sorted!
basically if i get in the car and the handbrake is engaged and turn the ignition on everything lights up as normal except the hand brake signal (P) in red looks like that, even when the car is started it doesnt turn on, and i release the handbrake and drive off and come back put the handbrake on nothing at all any clues or ideas?
handbrake light
ali50ferrari
The preacher is pious lord, for he is scared of hell, where as me I sinned freely trusting in your mercy
If the wire is properly connected check whether the mechanical switch is actually stuck and whether there is power going to it with the ignition on.
Could be as simple as a blown bulb in the cluster although this is pretty unlikely.
ali50ferrari
to test it, i jus have to get a tester (which i have) ground it usually in the cigarette lighter then connect the other end to the wire yh?
beema_boy
Yes it should light up when the ignition is on.
If it doesnt there may be a break in the wire or a blown fuse otherwise it will be to do with the cluster
Please visit our new store at:
www.phillyskate.co.uk
PM or email for FREE Phillyskate stickers through phillyskatestore@googlemail.com
The wire IS the switch - it's a pretty basic design, to say the least.capri_rob wrote:If the wire is properly connected check whether the mechanical switch is actually stuck and whether there is power going to it with the ignition on.
Chances are that bulb has blown, or even fallen out of the cluster.
ali50ferrari
Is it really possible that one bulb alone will pop and all the other 1s are working perfectly? what fuse number should i check? also the blue wire with the solid silver wire that threads through the copper bit looks fine and moves up and down ok. I jus checked it. . . ..
ali50ferrari
Soooo what number fuse could be related to the handbrake light bulb?
The fuse it runs from would affect a LOT more than the handbrake light!
ali50ferrari
so first port of call is the dash open it and check the bulb?
Bulb assemblies twist into the back of the cluster. You can just about change (some of) them by reaching up from underneath after you've removed the under dash panel.
