Jim320i wrote:By filrer do you mean air filter? If not, get that on your list... Your HT leads should be ok unless you know there is something wrong with them.
By head/profile gasket, do you mean the rocker cover gasket? If so, do the valve timing at the same time.
Sure the engine holds 4.2 litres... But 5 litres will be plenty.
Sorry yeah air filter is done. Oil and Fuel havn't
I'll grab 5L of engine oil, what about diff oil?
Well I've read a lot of horror stories of profile gaskets failing so thought before I put new oil in I may as well check it, and replace any other gaskets while I'm taking the head out.
