Dodgy seat mechs :/
Adams-Sideways
Post Wed Aug 31, 2011 9:45 pm
Hey guys, i have these seats in my 1986 325 . . .
On the outside they are in good nick but the mechs are useless. If i grab the top of the seat i can rock it back and fowards about 6 inches each way, not good, and when i lock the seat in the high position and sit on it, it falls straight back down. All in all very tired mechs!
Question is, can this be fixed or does this mean new seats :(
Any help/remedies would be great :)
Ad
Post Wed Aug 31, 2011 9:53 pm
Not worn, sounds like something has broken.
Only 2 nuts and 2 bolts to undo and take a look
Post Wed Aug 31, 2011 10:01 pm
I believe the mechanisms from the comfort style seats are the same as sports seats, so the stuff can be swapped over.
Someone confirm or correct me as I have 2 comfort seats in my garage which I keep meaning to strip for the mechanisms so i can chuck them out, if they are no good I'll throw them very soon :)
Adams-Sideways
Post Wed Aug 31, 2011 10:22 pm
I took them apart and oiled everything but couldnt find any bolts to check etc?
Post Wed Aug 31, 2011 11:05 pm
Mechs. are the same and easy to swap over, but it sounds like the seat in question may have a broken frame (MOT test failure).
The seat backs are held onto the base by two 8mm cross head bolts. These tend to work loose, and if the resultant movement is ignored, and the bolts not tightened (five minute job) the twisting force on the seat back soon leads to a broken frame.
Adams-Sideways
Post Wed Aug 31, 2011 11:07 pm
Right im gonna check these bolts tommorow, do you just have to take the back cover off to access them?
Post Wed Aug 31, 2011 11:55 pm
Back cover has to come off.
Tilt the seat back over as far as it goes, and you'll see two small cross head screws at the bottom. Take these out then pull out the bottom and lift at the same time.
The screws that work loose are around a third of the way up, and might be partly hidden by flaps of loose fabric.
Chances are though that the horse has already bolted, and the seat frame is cracked, leaving the catches on either side out of sync. with each other.
clipper
Post Thu Sep 01, 2011 12:31 am
Worth adding that if there is nothing broken and you do just have to tighten the crosshead screws than tighten them f.ing tight, than some more, as they will only work loose again if not.
Also I always thouth that comfort seats had only one gas spring on the backrest while sports had two, one on either side... maybe wrong though.
Ajsingh
Post Thu Sep 01, 2011 12:38 am
Sport seats also feel as if they sit lower than comfort seat. I deffo found a differance when i changed my seats
E30 Crazy!
**BANNED**
Post Thu Sep 01, 2011 8:57 am
There's more information here;
http://www.e30zone.net/e30zonewiki/inde ... orts_Seats
But the hinge mech is the same on all seats...4door/2 door/sport/comfort.
Differences between 2/4 door is that a cable/operating mech is added for backrest tilt.
Sport seat front tilt/theigh bolster are two seperate mechs added to the base frame.
The possible damage mentioned above is to the top of the hinge mech,it bends through 90 degrees and tends to snap on the bend.
Youth is wasted on the young.
asmith88
Post Thu Sep 01, 2011 11:24 am
same happened to me i took the seats out the other day as the drivers side was sitting at a back breaking angle,
took it out there was one of the bolts missing, found something similiar not the seat is lovely and tight,
1990 brilliant red 318 is
Adams-Sideways
Post Thu Sep 01, 2011 11:28 am
thanks for all the help, will investigate today :) then report back
polsta
Post Thu Sep 01, 2011 12:47 pm
sounds like yours have defo broke, the little bracket that holds the bolt
comfort and sport brackets do differ due to the extra ajustments
if broke, buy some whole mechanisms (adit prob has some) and swap the whole lot over, not a hard job to do
Adams-Sideways
Post Thu Sep 01, 2011 11:59 pm
Took the worst offender (drivers seat) apart today as described above and could not see anything broken, put all back together with those screws that secure the backrest very tight! And it still wobbles bad as ever, seems to be movement coming from under the plastic hinge covers on the sides. Are there bolts to check there? Also if i stand above the seat directly with it out of the car I can see the backrest is at an angle like the hinges are out of sync kinda?
kev76
Post Fri Sep 02, 2011 12:16 am
sounds like mine. it was the bar that runs between the back rest tilt adjusters . it runs under the seat and holds the seat cover down .mine had broke at one end.
DaveD
E30Zone Wiki Specialist
Post Fri Sep 02, 2011 10:03 am
why not do the job properly...go into the wiki link that daimlerman posted open the link in there...its a step by step guide... and dismantle the seat totally and reassemble...it isn't hard
Adams-Sideways
Post Fri Sep 02, 2011 12:33 pm
That is all good and well, and is pretty much what i have done but struggled to find anything broken :(
**BANNED**
Post Fri Sep 02, 2011 2:13 pm
Some seat problems are less obvious until the thing is in bits....
Adams-Sideways
Post Fri Sep 02, 2011 8:08 pm
Ahhhh i see, right will crack on taking them FULLY apart then :) how much do a decent set of sport mechs go for?
Post Sat Sep 03, 2011 12:13 am
Usual place I find they break is around the weld that holds the short piece of thick walled tube to the relatively thin sheet metal of the side of the frame, near the top left of Daimlerman's pic. of the base.
The damage can usually be successfully welded if you're half competent with a MIG, and without stripping things down quite as far as in the pics.
Adams-Sideways
Post Sat Sep 03, 2011 12:18 am
got a mate thats handy with mig so could be done :)
DaveD
Post Sat Sep 03, 2011 9:46 am
not very much if the covers are in a poor state...its the carriage that costs. they are usually repairable
Adams-Sideways
Post Sat Sep 03, 2011 9:50 am
right will get cracking with these asap
