Not able to reset the service lights...
rover-2000
Guys
Our Touring has both the clock/oil and orange/red service indicators lit. I bought a reset tool, plugged it in and tried to reset them with ignition on. Both the LED's on the unit lit and went out no problem, but it had no effect at all on the dash lights! Any ideas why this might be?
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
polsta
dont know but try just a piece of wire next, to just see if its the tool at fault
clipper
If its of any help I have to start my car with the wire in place to get the SI to reset, doing it with just the ignition on won't do it.
Probably telling me that the batteries are on there way to "a better place" but the last two services I've had to do this.
rover-2000
Will give that a try-thanks.
Kind regards
John
1989 320i Touring
John
1989 320i Touring
adit
did you turn the ignition on before turning on the reset tool?
[quote="bss325i"]
rover-2000
Yes-I did as described previously on here.
Kind regards
John
1989 320i Touring
John
1989 320i Touring
m8782538
i just use a piece of wire, its a lot cheaper than buying a tool and has worked fine on mine.
rover-2000
Hmm....tried it with the engine running, but they still don't turn off....any other ideas?
Kind regards
John
1989 320i Touring
John
1989 320i Touring
If you're sure you've been trying to reset them properly, then the batteries on the SI board are probably shot. Good idea to replace them before they leak acid over the circuit board!
rover-2000
I did wonder if that might be the problem. Are the batteries easy to fit?
Thanks.
Thanks.
Kind regards
John
1989 320i Touring
John
1989 320i Touring
Not a difficult job, but they are the type with tags on the end that are soldered in.
rover-2000
Ah yes-just found it on the Wiki. I'm going to Maplin next week-might as well give it a go for a few quid!
Kind regards
John
1989 320i Touring
John
1989 320i Touring
Check which batteries you have first - NiCd or Lithium.
They are not interchangeable, and lithium ones don't normally cause problems anyway.
rover-2000
So I can't fit Lithium in place of nicd then? That's not clear in the Wiki......
I am thinking that mine must be faulty because I have tried everything else to reset the lights. Annoying that the car will need to be off the road whilst I sort it out-I was hoping to get the batteries, strip and reassemble, but by the sound of it I need to remove and strip, THEN Go and get batteries, then refit.....
Oh well, these things are sent to try us!!
Kind regards
John
1989 320i Touring
John
1989 320i Touring
You can drive the car (illegally - no speedo) without the cluster fitted.
There's a theoretical chance that the battery won't charge, but in practice it does.
