Me again...
My E30 has a factory fitted alarm and imobiliser and its doing my head in! Its so loud! Sounds like a microwave, beeps all the time when i open a door or everytime i close it.. just doing my nut in! Now i know theres a key to turn the system off but im not keen on doing that. I tried having a peek in the plug for it but the alarm went off and i bricked it! Haha
Anything i can do?
Ben
318is - OEM Alarm & Imobiliser Noise!
May be missing something here, but I thought alarms were supposed to be loud.
There's a key switch on the sounder to turn it off.
polsta
thats just how the alarm is ben
in the engine bay on the alarm siren, open the little cap and turn the key in there and it turns the siren off
but- just live with it , remember its an old alarm system designed 20 odd years ago !
It was, and it's a lot more effective than most of the modern stuff, which almost all lack one very vital component.polsta wrote: , remember its an old alarm system designed 20 odd years ago !
polsta
which is ?Brianmoooore wrote:It was, and it's a lot more effective than most of the modern stuff, which almost all lack one very vital component.polsta wrote: , remember its an old alarm system designed 20 odd years ago !
the alarm always worked fine...just didnt like being left, ie getting out you had to leave key on 1 click, or it would set, didnt like being left with a window or sunroof open a bit etc, but at least you know if any trouble the f**ker would go off properly and wake up the whole neighbourhood
It's own internal battery. Any alarm without its own back up battery is silenced in a couple of seconds by bolt cutters through the battery earth lead, giving all the time needed to bypass the immobiliser and otherwise disable the alarm.polsta wrote:which is ?Brianmoooore wrote:It was, and it's a lot more effective than most of the modern stuff, which almost all lack one very vital component.polsta wrote: , remember its an old alarm system designed 20 odd years ago !
A jump lead from the battery negative terminal to chassis, and away you go.
