Hey guys,
Recently installed a remote central locking unit in my car today,
However I can no longer unlock or lock the doors with my key??
Its a e30 318i I dont have an actuator in the trunk and therefore
actually mounted my new unit (wrapped in plastic) back where the
Old one came from, locks and unlocks fine with the remote just not with the key, can anyone explain why this would be??
Thanks Very much guys
Harrison Sal
Central Locking Wiring questions
- **BANNED**
Driver's door should unlock with the key,it's a mechanical linkage,from the diver's door solinoid,the signal is sent to the other locks....
Youth is wasted on the young.
harrysal
Hey daimler, I Connected in new actuators, control module today, the problem is the key doesnt do anything anymore (probably because i havent connected something) i believe the wires i had left over after wiring in my new CLCU were two green/purple and a red brown? I had to connect in new actuators as it double locked my passenger door and I replaced the drivers one as a precaution as i was getting shorts.
- **BANNED**
On the back of the lock barrel is an L shaped arm,this connects directly into a fork on the door latch,so turning the key moves the fork,which in turn dis-connects the outside handle and pulls the internal lock button down.
My best guess is that your L shaped arm has gone walkies....a lock repair kit is perhaps your best bet,from the dealer here in the UK,they cost about £20.You get a bag of bits that enables you to build a new lock barrel to suit your key.
Welcome to the zone,BTW!
harrysal
Thanks very much! I'll see what i can do about tracking one down over here in OZ, cheers for the help (:
Just was very confused because it used to unlock the central locking by the key and now it doesn't I simply thought it must have been a simple me not wiring something up right (: Thanks for clearing it up.
Harrison Sal
Harrison Sal
- **BANNED**
