Guys
A problem with the doorlocks on our new touring!
If I lock/unlock from the passenger side, it works perfectly. If I lock from the drivers side, nothing happens until the key is horizontal and the key is hard to turn to get it there-it then locks. If I lock the car from the drivers side, I cannot unlock from the passenger door!
Any ideas whats going on?
Thanks.
Door lock problem
rover-2000
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
Turning the key to the horizontal position in the drivers door activates the deadlock so you cannot unlock it from the other door or tailgate.
you should be able to lock the car normally ( i.e not deadlocked ) from the drivers door so sounds like something has gone wrong but this is the exact problem I had with my previous E30 - I just learned to live with it and got used to locking all the doors from the boot lock if I didnt want it deadlocking
E30 Central locking is not the most reliable due to the position of the relay ( drivers footwell behind the speaker - can get wet ) and the design of the wiring loom into the doors which also can allow moisture in which makes the connections play up.
Search for red/black wire modification in this section will tell you a useful free mod you can do which solves a lot of C/L problems.
There is an L shaped alloy piece on the back of the driver's lock barrel which is supposed to swing from side to side as the barrel is turned between the two locking positions. It sounds like this may have seized on its shaft.
CaesarBob
I had the same problem with my door lock. I'd wager the problem is that the lock mechanism is worn.
Have a look at this web page: http://www.billswebspace.com/BMWE30Door ... ebuild.htm
The repair kit (which is basically a new lock in pieces) is still available from BMW for £18 + VAT.
'97 E36 B3 3.2 Touring - Alpina-Blau
'15 F32 420d M Sport Coupe - BMW - melbourne-metallic (Sold)
'11 E92 320d M Sport Coupe - BMW-saphirschwarz-metallic (Sold)
'99 E36 328iA SE "Shooting Brake" - BMW-titansilber-metallic (Sold)
'89 E30 325i
'89 E30 325i
rover-2000
Thanks guys-that's a lot clearer. I will take the trim off and see what awaits.....
Kind regards
John
1989 320i Touring
John
1989 320i Touring
- **BANNED**
The 'lock repair kit' gives you a bag of bits to build a new lock to suit your key,and transforms the feel and confidence in your car!
Have a look in the zone 'Wiki',link at the top of every page,for 'Central locking problems',and work your way though these as well.
Youth is wasted on the young.
