Can somebody tell me where all the earth & ground cables are in & around the engine bay please.
Need to sort out an annoying electrical issue.
Earth/ground cables...
e30-EVN
the main earth strap in on the engine mount arm and bolts to the chassis rail
A 2 door e30 with 8 cylinders, what could be better
- **BANNED**
Earths are plain brown wires;there's certainly an earth stud on the inner wing in the general area of each headlight.
Youth is wasted on the young.
E30 earth points are: Top of RH front suspension strut, on the inner wing behind the LH headlamp, behind the glovebox on the bulkhead, and at the LH side of the rear seat pan.
There's also a minor earthing point on the screws that hold the steering column switches, and of course the very important engine mount to chassis rail earth strap, whose location varies with models.
