OBC Code Problem
baybee
Post Sun Aug 28, 2011 8:08 pm
Having problems getting the code function to work on obc.
gif upload
The way I understand how this works from the diagram is as follows.
There is always power going into the relay box from the instrument cluster. by default the horn relay is always open and the immoblizing relay is closed. When you enable the code function, the obc directs the power from the cluster to the immobilzing relay, opening it hence losing continuity in the green and green/red wire. when you put in the right code the relay closes again and if you put the wrong code three times power is fed to the horn relay.
Whats happening with mine is
I am getting about 6 volts on the red/white wire from the cluster and br/yl coming from the obc. When you put the wrong code 3 times it goes up to about about 12 volts and the horn relay ticks as expected. Between the rd/white from the cluster and br/bl from the obc im getting no voltage whether the code is enabled or not so the immobilizing relay is not opening. I have tested both the relays in the relay box and there are working fine and the br/bl wire from the obc seems intact.
Would i be right in assumuming the obc unit is not faulty?
