Using a rear e30 beam to make a trailer+ pics
jimmyspeed
I am starting to make a trailer out of old rear beam i have lying about and i need to remove the diff and driveshafts so that the weight it cut down
What i need to know is whether the rear hub and bearing assembly will function without the rear driveshafts ?
Ideally i want to take them off and cap the back of the hub with my welder but i dont know how it all looks inside
I could have a look at whats inside the outer cv joint but i thought i might as well ask before i wreck the clips holding the boot in and get covered in grease !!!
Thanks for any help
Thanks for any help
- **BANNED**
Easiest way may be to ask Mr Angle Grinder to chop the drive-shafts close to the inner side of the hub....then the remains of the shafts are still supported and run as intended,but you can save the wieght of both the shafts and the diff.
Will you use the stock type rear springs with a fabricated upper spring seat under the trailer?
Youth is wasted on the young.
jimmyspeed
hi daimlerman
So you reckon they will be supported if i cut them of before the cv boot and not just flap and vibrate around ? cus they seem like they will sag under ther own weight
as for the springs i hope to use them but they might be too extended with the lack of weight and maybe set the trailer at an angle, i will mock up a basic frame once the metal has bee collected and swapped for 50mm box not 50mm angle !
also kept the dampers too so might fab them in as well if i have enough metal
- **BANNED**
Do'nt know,but the driveshaft is supported there,the c/v joint just allows the diff to sit attached to the frame of the car to allow for suspension movement.jimmyspeed wrote:
I wouold have 'thought' that just using the sliced driveshaft as a stub axle would work,what do others think?
You will struggle with the damper mount,though,that's well above the upper spring mount!
Duke137
You could just buy a trailer?
But a valliant effort, get some pictures up!
- **BANNED**
Little more than slicing the boot area off a redundant saloon,then lightening as the OP suggests will make a usefull and 'different' trailer!
jimmyspeed
You could just buy a trailer? very true but for the size i want your looking at alot of money, and this way i get to try out/practise my welding and custom build it to carry my motorbike
at daimler, there are a few pictures of such a trailer online but just not big enough for my needs as for the upper spring mounts they are alot higher on the e30 but the dampers themselves really compress down almost to half so even slightly extended it might be useful to stop the trailer jigging about especially when empty
still keen to know if someone has taken one apart ?
will get pictures as its being built
- **BANNED**
Interested,keep us up to date with your build.
kman82
This is interesting, not seen an E30 trailer before. hope you can pull it off. some inspiration nicked from the German show pictures
jimmyspeed
looks pretty good, mine sadly wont look that good ! i did have the whole car but not the time or space to brake and keep the necessary panels or skills to make it to be fair - will be more like a normal box trailer
i will try and use e30 lights though as i have a couple of sets and the section of wiring loom needed
I've never even taken the rubber boot off of an E30 driveshaft, 'cause I've never come across a duff one, but I'm an ex Mini man, so have taken apart plenty of their CV joints, which I expect are similar in construction.
Under the rubber boot will be a cage and some large ball bearings. The drive shaft will have a splined end which fits into the cage, and will be retained by a circlip of some kind.
Remove the driveshaft, and the cage will be able to be turned far enough to release the balls, leaving just the outer part of the housing.
bastosm3
use the outer cv joint, the hub bearings are held together by it, I would remove the driveshaft and then it's not flapping about !
jimmyspeed
thanks for all the help - it looks like i will have to take it apart then and keep the cv joint, i thought from the pictures the driveshaft went all the way through, but if the cv joint is holding the bearings in thats all good. i will dismantle them later
pictures
This is what is behind the cv joint a nice watertight hub, there is a strange layer of rubber in between the castings which i cut and ground flat. I guess it to remove vibrations, looks like polystyrene balls?
https://lh4.googleusercontent.com/-M3Fc ... C00044.JPG
cv joint with balls- degreased - am amazed at the design, genius invention
https://lh6.googleusercontent.com/-pzCS ... C00045.JPG
pictures
