I have tried using the search function but got confronted with threads about stolen badges and other such irrelivant garbage.
A friend I used to work with recently had some one fit a 2.5 engine to his 1.8i. It runs but the only dial that works on the dash is the petrol gauge.
I assume that there are some pins that need moving on the loom or 2.5 dials need fitting but I'm not sure?
Gauges not working 318i > 325i conversion
rix313
If both engines were facelift, then all should work with no rewiring at all, except for checking out the warning I've stickied in the engine swaps forum, but you would have already discovered this by now!
If one loom is a late pre facelift, and the other facelift, then the engine speed (rev. counter) and fuel rate signals won't get through.
The 1.8i instrument cluster will need the coding chip from the 325 fitted to the front of it, or the rev counter will over read by 50%.
