Welding
m8782538
Post Thu Aug 25, 2011 11:37 am
I think i am going to get a good used No Gas Mig and attempt to do the welding repairs on my 2dr, rather than paying out 4 figures to a garage.
Help and advise is needed though.
Sills are rusty and a couple of splits, i know i can fill the splits, what am i looking for so i can tell if a repair will be suitable or I need to replace the sills totally?
One Sill has rusted quite a bit by the front wheel arch and missing a small section, can i weld a replacement section of steel on or do i have to replace the whole sill?
I patch underneath is required which should be easy enough, going to use the old wing i am taking off and replacing (is this suitable?) as the patch is small and just behind the front wheel arch around the footwell area, the corrosion is only in that 1 area, checked that already.
Duke137
Post Thu Aug 25, 2011 11:50 am
Gasless are completely shyte you need gas to do it properly. In addition the CO2 "throwaway type" cannisters some companies sell don't last 2 minutes either, best off buying the complete welder and gas rig, problem with that is it will cost a minimum £300 tbh
You have to decide if its just easier to pay someone £300 to weld it for you
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Aug 25, 2011 11:52 am
1) Gasless is useless. It's sloppy, hard to control, and requires loads more work after you've welded to remove the splatter. A bottle of Argon/Co2 mix with 0.6mm wire is easier to use AND gives better results.
2) If the metal has split, you can't just stitch it together. You need to cut either side of the split to GOOD metal, and put in a new patch.
3) If the sill is rusty at the front, it's probably rusty on the floorpan and the bulkhead too. You can buy a new sill and just cut off the bit you need (easier and quicker than doing a whole sill), but you'll still need to fabricate your own sections for the other two parts.
4) You can use metal from old body panels; just remember that all paint and rust needs to be removed from them so that impurities don't get into the actual weld.
www.mig-welding.co.uk is a great website and forum for this sort of stuff, and there's a few BMW E30 resto's on there already for reference (including my own.)
As a quick guide on price; I bought my welder on Ebay over christmas. 135 quid for a Snap On 130A machine, which is perfect for bodywork repairs like these. Then about 15 quid for the regulator, and you can get a big cylinder of CO2 for less than twenty quid these days.
m8782538
Post Thu Aug 25, 2011 11:53 am
i can only weld outside, no garage, and the cheapest estimate for the welding so far has been £1200 so would probably be cheaper for me to buy a no gas mig and do it myself.
Reparied one of my old cars after smash with a no gas mig and it was fine.
Alternative is to find someone locally who can weld and wants to take the job on, bare in mind the car is on my drive, not drivable to would have to bring all their equipment to me to carry out the work, plus it would have to be done outside which makes using gas tricky to say the least.
Hence asking on here, i don't know what to do? Finances are tight, has to be completed by christmas or it won't be done until sometime in 2013, by then be in much worse condition and cost more to sort out.
Duke137
Post Thu Aug 25, 2011 11:56 am
m8782538 wrote:i can only weld outside, no garage, and the cheapest estimate for the welding so far has been £1200 so would probably be cheaper for me to buy a no gas mig and do it myself.
Good luck then :mad: [/b]
randomspeedfreak
Post Thu Aug 25, 2011 11:58 am
where are you based?
im not too shabby at sticking and have my own equipment. could do it for a shade of what youve been quoted
EDIT* just seen youre in swindon. im in bristol or reading so would be up for coming down if it intrests you
Last edited by randomspeedfreak on Thu Aug 25, 2011 11:59 am, edited 1 time in total.
m8782538
This project is a nightmare which i have to complete, no other option. driving me insaine. Wifes uncle's car originally which required the resto and i took it on and am able to keep the car, car must stay in the family and i said i would restore it and i always stick to my word. aaarrrrggghhhhh, stupid principles. :x
Grrrmachine
Post Thu Aug 25, 2011 12:00 pm
m8782538 wrote: it would have to be done outside which makes using gas tricky to say the least.
Just chop up and old cardboard box and make a windbreak, it's not that tough. Unless you're trying to weld in a hurricane.
I can understand budgets are tight, but what you save on using gasless you'll double in grinding discs, getting the weld flat.
m8782538
Post Thu Aug 25, 2011 12:35 pm
randomspeedfreak - you got mail mate.
