suspension
mani
lads i just wonted to know if there was any1 that had a step by step guide on how to remove front suspension (spring and shock absorber) because i would like to fit new set of coilovers .
Rtaylor2208
From memory this is how I did it with advice from Daimlerman. Just the removal, I was only replacing the springs not fitting coilovers.
1. Loosen but do not remove the 17mm nut on the top of the front struts while the car is on the ground.
2. Raise the front of the car and put on Axel Stands
3. Remove the wheels
4. Using a scissor type ball joint splitter disconect the track rod end
5. Using a scissor type ball joint splitter disconect the Wishbone from the hub.
6. Remove the brake caliper
7. Disconnect the front ARB, this gives you more room to get the strut out.
8. Have someone support the strut while you remove the 3 13mm nuts holding the strut to the turrent under the bonnet.
9. Remove the strut from the car
10. Compress the spring.
11. Remove the 17mm top nut from the strut, you may need to hold onto the damper with a set of mole grips to stop it spinning the nut. I ended up paying a mechanice a £10 to do this bit as I couldn't shift it.
12. Disassemble the strut making a note of the order everything came off
