part number
SickEddy
Post Mon Aug 22, 2011 5:58 pm
hi. i am after a part number for a tube that goes under the inlet manifold and connects to the throttle body and the valve cover. i have the tube and the number on it aparently doesnt exist, i think it has partly worn off. its a Z shape tube. i would usually use realoem website but its down at the moment. thank you in advance for any help
Jozi
Post Mon Aug 22, 2011 7:10 pm
For what engine?
Try: http://bmwfans.info/parts/catalog/E30/ it's much the same as realoem but with pretty pics :)
Post Mon Aug 22, 2011 8:08 pm
It'll be an M20 i suspect.
Part number 11151708801
No. 3 on here
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
SickEddy
Post Tue Aug 23, 2011 1:37 am
cheers guys and yes it is an m20. i had the part number 1708 8012 but not the first bit. thank you
alpinab6s
Post Tue Aug 23, 2011 3:17 am
JUST CHECK OUT REALOEM.NET :eek: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea:
Jozi
Post Tue Aug 23, 2011 4:17 am
alpinab6s wrote:JUST CHECK OUT REALOEM.NET :eek: :idea: :idea: :idea: :idea: :idea: :idea: :idea: :idea:
He did but it was down, no need to shout either
Post Tue Aug 23, 2011 6:47 am
+1. Calm down love!
