Hi,
Now that the car is goiung off the road again as the tax is out I am going to try and fix all the nigglinh issues. The first one is the powersteering.
Its a 325i 89 cab.
On full lock left or right something squeels, to be honest I think its the pump as it has done it since I got the car and the belt has been replaced when I replaced the snapped fan belt.
The rack also seems fine as far as I can tell. It did have a leak from the resivior but thats fixed once i had replaced the old jubilee clips and replaced the fluid.
Any pointers or is it a new pump?
Squeeling Powersteering on full lock
Rtaylor2208
SickEddy
i also have this problem. on full lock it makes a squeeling noise even when the car is stationary and the steering wheel seems to want to move back a bit. i have checked and the wheel is nowhere near scraping on anything. everything works ok so i have not checked any parts. i am curious to what this is but as it doesnt seem to do any damage or affect my driving i have never bothered.
threelander
sounds like the belt slipping to me guys.check that out
e30-EVN
as above and also worth noting, as brianmoore will most prob say if he see's this..... one should never hold the car in the full lock position as it puts excess strain on things!
A 2 door e30 with 8 cylinders, what could be better
Rtaylor2208
Checked the belt and the tension appears to be correct. The car was stupidly low before I changed the springs and always put it down to the tyres rubbing. Will check at the weekend once the car is back up on the Axel Stands.
