Engine mounts ...
spic
Post Sun Aug 21, 2011 9:36 pm
Hi folks. after a little bit of sprinting up prescott hill today I noticed when I hot home that both my engine mounts on my 327 M20 engine were destroyed 8O
whats are the best options to go for ... am I right in thinking you can use ford mounts which are slightly stronger ?
e301988325i
Post Sun Aug 21, 2011 9:42 pm
It looks like burton power could again be the supplier for these if E21 mounts are unvailable:
FP292 for engine mounts and FP291 for gearbox, best to ring them as 'm only going by scale on the gearbox mount.
http://www.burtonpower.com/catalogsearc ... 80&q=mount
I said:
e30topless said:
lock the wife in there
spic
Post Sun Aug 21, 2011 10:04 pm
Thanks for the link . Any idea if I should go for the thick or thin ones ???
Post Sun Aug 21, 2011 11:32 pm
the standard ones are fine. Your 2.7 won't be a torque missle which will destroy engine mounts for fun.
e301988325i
Post Mon Aug 22, 2011 7:23 pm
spic wrote:Thanks for the link . Any idea if I should go for the thick or thin ones ???
e301988325i wrote:FP292 for engine mounts
I said:
e301988325i
Post Mon Aug 22, 2011 7:24 pm
Simon13 wrote:the standard ones are fine. Your 2.7 won't be a torque missle which will destroy engine mounts for fun.
Very true, but how much?!
I said:
